Results 1 to 12 of 14
Plumbing & Plumbers Forum - pipe repair problem
Like Tree9Likes
pipe repair problem
Discuss pipe repair problem at UK Plumbers Forums; I have 4 22mm pipes (hot cold and two central heating) all running together ( no gap between them). someone has put a nail in the second pipe. i can ...
    Oct 2016
    Default pipe repair problem
    I have 4 22mm pipes (hot cold and two central heating) all running together ( no gap between them). someone has put a nail in the second pipe. i can not separate the pipes to cut and couple. And suggestions?
    Nov 2012
    147
    Default Re: pipe repair problem
    I've never used this stuff myself, but a customer had repaired a pipe under the floor that had poor access and it worked fine. Not sure it is a permanent solution though.
    https://sylmasta.com/catalogue/produ...er-stick-113g/
    Oct 2016
    Leeds
    139
    I have used what Nick suggested once before on a copper cylinder that had a pin hole in it. It was only on for a week while I sourced a new cylinder but it did work. Didn't trust it though to just leave it like that permanently, it does claims to be a permanent repair though if you wanted to risk it.
    croppie likes this.
    9,683
    cut all 4 and used 4 slips and 4 normal couplings and solder the lot (dont put a coupling on the timber joist cut a few inches to the left or right etc)
    Last Plumber and Masood like this.
    Paulplumb's Avatar
    Aug 2010
    Worcester
    862
    never tried one but you can get these now. clean pipe, flux and fit on pipe. heat till the solder ring melts go down the pub
    Last Plumber's Avatar
    Aug 2016
    Lancashire
    1,131
    If the nail is only in one side you could wipe a patch on it !
    Mar 2013
    1,340
    If doing patch or making solder repair, vent/open pipe to air, so internal pressure does not effect flow of solder.
    Last Plumber likes this.
    Aug 2016
    Lancashire
    1,131
    Quote Originally Posted by joni os View Post
    Like it, same wave length, good call
    tamz's Avatar
    Scotland
    13,928
    Can't cut it! Try pulling it.
    It will lift up or as said if its only through one side, wipe some solder over the hole.
    Its not pianos yer building here.
    Mar 2008
    513
    That reminds me of my old Dad, " for Christ sake son, your not mending a f###### watch"
    tamz, Stigster, Masood and 1 others like this.
    Aug 2015
    284
    I made a patch using JB Weld epoxy and a piece of abrasive clean up strip to fix a hole in van's hard to remove coolant pipe. Around 3 years on and still holding...
    The clean up strip is grp so very strong and the resin heat and pressure proof (relatively).
    Masood's Avatar
    East London / Essex border
    4,769
    Quote Originally Posted by NickH View Post
    Or my old man when I was trying to be too neat with the flux. "You're not f***king Mike Angelo" in his thick Indian accent...
    Happy days... God I miss the old sod sometimes. All the time, actually...
    Find us at:
  1. 6mm copper pipe repair ?
    By JCplumb in forum Plumbing Forum
    Last Post: 15-09-2015, 07:46 PM
  2. Damaged pipe repair?
    By 108pb in forum Plumbing Forum
    Last Post: 03-09-2015, 04:40 PM
  3. cast down pipe repair
    By dean4drains in forum Plumbing Forum
    Last Post: 30-03-2010, 10:41 PM
  4. Plumbing pipe repair
    By FredEggnChips in forum Plumbing Forum
    Last Post: 07-05-2009, 09:21 AM
