Results 1 to 12 of 18
Plumbing & Plumbers Forum - Where to buy boss (double Socket – same side)
Like Tree3Likes
Discuss Where to buy boss (double Socket – same side) at UK Plumbers Forums; Where can I get hold of a boss (double Socket –same side) 110mm x 40mm I've goggled this and can't one. Like this (I photo shopped this picture) https://1drv.ms/i/s!AlXOOGaTv36QgQuVPv22GNk2dCzK...
    Oct 2016
    18
    Default Where to buy boss (double Socket – same side)
    9,984
    Default Re: Where to buy boss (double Socket – same side)
    Just glue two strap on bosses onto a piece of pipe done
    mutley racers likes this.
  3. The Following User Says Thank You to ShaunCorbs For This Useful Post:
    Nov 2015
    Leicestershire
    yep, two strap on bosses the way to go.
  5. The Following User Says Thank You to Poppa Spike For This Useful Post:
  6. #4
    Oct 2016
    18
    I know you can use straps but can you not buy doubles on the same side ?
  7. #5
    rpm
    rpm is online now
    Member rpm's Avatar
    Wherever I lay my hat
    7,958
    Warning- It`s for underground connections and Kloor will go for her guns if you call her mate!
    lol
  8. #6
    Mar 2013
    1,446
    Bossed connection not normally used underground. Would normally Tee off 110x110 and reduce to 40mm above ground. Please give further details of installation.
  9. #7
    rpm
    rpm is online now
    Member rpm's Avatar
    7,958
  10. #8
    Chalked's Avatar
    3,922
    Why don't you just use two polypipe short boss pipes?
    Attachment 27700
  11. #9
    Mar 2013
    1,446
    Quote Originally Posted by rpm View Post
    In the above situation connecting to external 110mm underground, the standard method would be to connect via a back inlet gully. These now come with removable internal sleeve, allowing direct rodding to main run. I know the length of run may be minimal but building inspectors can prove rigid on such matters,
  12. #10
    N.Ireland, United Kingdom
    6,990
    Why can you not use two of the 110 x 40mm bosses joined together? They will meet up tight, similar to what you showed
  13. #11
    rpm
    rpm is online now
    Member rpm's Avatar
    7,958
    Maybe Kloor`s alternative is the way to go?
    https://1drv.ms/i/s!AlXOOGaTv36QgQjSNZa1BdvGWKrI
  14. #12
    Oct 2016
    18
    Yep - that shows you what I have in mind for the double connector
    PS my dad calls me "mate" all the time
    PPS the reason for not using 2 bosses is that I just trying to be tight - mind you may cost more to get a double :-)
  1. single or double ended socket soil pipe
    By Mgrant in forum Plumbing Forum
    Last Post: 28-03-2016, 09:27 PM
  2. Replace a boss connection with a strap on boss?
    By michcosg in forum Plumbing Forum
    Last Post: 01-02-2016, 01:10 PM
  3. Single panelled rad for double panel, double fin help please
    By wrightk in forum Central Heating Forum
    Last Post: 24-02-2015, 11:54 PM
  4. Socket set
    By rob2048 in forum Plumbing Tools
    Last Post: 28-06-2013, 09:44 PM
  5. Filling loop double check valve - which side?
    By M.Joshi in forum Plumbing Forum
    Last Post: 07-04-2012, 06:03 PM
