Page 2 of 2 FirstFirst 12
Results 13 to 18 of 18
Plumbing & Plumbers Forum - Where to buy boss (double Socket – same side)
Like Tree3Likes
Discuss Where to buy boss (double Socket – same side) at UK Plumbers Forums; Connections into vent not underground, post 5 misleading. Sink waste can boss onto vent up to 500mm above ground. Shower waste depends on branch to WC. 110mm Tee to WC ...
  1. #13
    Mar 2013
    1,484
    Default Re: Where to buy boss (double Socket – same side)
    Connections into vent not underground, post 5 misleading. Sink waste can boss onto vent up to 500mm above ground. Shower waste depends on branch to WC. 110mm Tee to WC with provision for 40mm boss at 90 degrees would suit if branch can be positioned low enough to give 1:40 fall from shower but best solution would be to have WC branch coming in at level of WC outlet, approx. 150mm above floor and use new back inlet gully, connected independently to main run, for shower and sink waste. Tell your plumber to start digging.
  2. #14
    ** UKPF Sponsor **
    Ray Stafford's Avatar
    Sep 2012
    Fareham
    10,124
    A polypipe SWA43 gives you two boss inlets in the same plane on the same fitting.
    Costs way more than a pair of strap bosses though...
    Chalked likes this.
  3. #15
    tamz's Avatar
    Scotland
    13,977
    Or alternatively use a soil manifold which may work out better
  4. #16
    Mar 2011
    573
    Am I the only one that dislikes strap ons...oo err.
    much rather have a boss pipe where possible, strap ons a last resort for me
    Best likes this.
  5. #17
    N.Ireland, United Kingdom
    7,109
    Quote Originally Posted by tolly View Post
    I also never liked them. Handy if a boss fitting is a hard job to fit. They always look an add on and if the solvent has been plastered all over the joint makes them an eyesore.
  6. #18
    2,046
    Double socket, same side
    And it looks like 2 the other side as well.
    Turn the 110 branch into a rodding access.
    Or turn it around and bury it in the wall.
    110mm PVCu Solvent Weld Soil Pipe Bossed Branch 92.5 Degrees Double Socket 453
  1. single or double ended socket soil pipe
    By Mgrant in forum Plumbing Forum
    Last Post: 28-03-2016, 09:27 PM
  2. Replace a boss connection with a strap on boss?
    By michcosg in forum Plumbing Forum
    Last Post: 01-02-2016, 01:10 PM
  3. Single panelled rad for double panel, double fin help please
    By wrightk in forum Central Heating Forum
    Last Post: 24-02-2015, 11:54 PM
  4. Socket set
    By rob2048 in forum Plumbing Tools
    Last Post: 28-06-2013, 09:44 PM
  5. Filling loop double check valve - which side?
    By M.Joshi in forum Plumbing Forum
    Last Post: 07-04-2012, 06:03 PM
