Results 1 to 12 of 13
Plumbing & Plumbers Forum - connecting old copper pipes
Like Tree8Likes
Discuss connecting old copper pipes at UK Plumbers Forums; i have recently had to fix a leak on a section of old copper pipe. the pipe is slightly bigger than 22mm and is thick enough to have had a ...
    Oct 2016
    Default connecting old copper pipes
    i have recently had to fix a leak on a section of old copper pipe. the pipe is slightly bigger than 22mm and is thick enough to have had a thread put on it. any ideas how to replace a section with 22mm copper?
    there has been mention of a transitional coupling, however this a DHW pipe
    Jan 2016
    grappenhall warrington
    305
    Default Re: connecting old copper pipes
    it is probaly 3/4" copper you can get 3/4 to 22 soldered
    couplings
    9,673
    Quote Originally Posted by Gasmk1 View Post
    couplings
    3/4 copper is smaller than 22mm not bigger
    Last Plumber's Avatar
    Aug 2016
    Lancashire
    1,127
    It might be the really really old stuff before 3/4
    It was more like 1/2" iron for size O.D.
    Last time I dealt with it I think I soldered or brazed a female iron to copper on the end of it.
    If it is that stuff ( and it sounds like it ) you won't find a manufactured fitting for it.
    ShaunCorbs likes this.
    Aug 2016
    Lancashire
    1,127
    Measure O D and post the size.
    Can you not replace it all ?
    ** UKPF Sponsor **
    Ray Stafford's Avatar
    Sep 2012
    Fareham
    10,089
    Use a drift or socket former to create a socket in the end of the old pipe, and then solder 22mm pipe into it.
    Roger Welton likes this.
    Chalked's Avatar
    3,814
    Quote Originally Posted by Ray Stafford View Post
    A drift won't work Ray. It sounds like screwed copper, it it slightly larger than 22mm. Normally found in old high end houses. Nobody makes a transition fitting, and the threads are " fine taper" so BSP is nowhere near. The copper is as thick as galvanised pipe, so great for scrap.
    The times I have connected to it, we used a 1"BSP male to 22 mm compression fitting. The 1" thread will slide over the pipe and either solder it using leaded solder ( I know!!) or better still hard solder or braze. Then you have a 22mm compression end to go off.
    chris watkins and Masood like this.
  8. The Following User Says Thank You to Chalked For This Useful Post:
    Jun 2012
    London/Kent
    3,950
    There speaks a proper plumber. IMHO
    Problem what problem !
    With his skills & knowledge he can adapt, repair, overcome & only if absolutely necessary replace to fix the problem.
    Chalked, Ray Stafford and Masood like this.
    ** UKPF Sponsor **
    Sep 2012
    Fareham
    10,089
    Every day's a school day! I don't think I have ever seen that type of pipe.
    Jan 2016
    305
    i have never come across that size or type of copper before must be from the 40's or 50's ?
    Chalked's Avatar
    3,814
    This is the only image I can find on google. This pipe is brass, but it's the same for copper and they have brass fittings.
  13. #12
    Oct 2016
    Thank you
    will give it a try tomorrow, exactly as you said, old high end house
    Chalked likes this.
  1. Connecting onto old 1 1/2 inch copper waste
    By Bob Hill in forum Plumbing Forum
    Last Post: 23-09-2014, 02:15 PM
  2. Connecting PEX to Copper?
    By PinkyPerky in forum Plumbing Forum
    Last Post: 11-02-2014, 12:18 AM
  3. Why replace old 3" iron pipes with small copper pipes?
    By mandries in forum Plumbing Forum
    Last Post: 25-04-2013, 05:29 AM
  4. Connecting toilet to 15mm copper
    By James100 in forum Plumbing Forum
    Last Post: 29-07-2010, 10:51 AM
  5. Connecting copper to lead.
    By a9blue in forum Fittings & Pipes
    Last Post: 07-04-2008, 03:19 PM
