Came across this pipe in the Leicestershire area (if it's the same stuff). Heavy gauge copper, screwed. It's called 20-gauge and you can buy compression and end-feed transition couplings for it. The end-feed couplings are brass and cost a fortune but it means you can convert to 15mm or 22mm and weigh in the old stuff...
