Results 1 to 10 of 10
Plumbing & Plumbers Forum - 3/4 Brass coupling with nylon thread, why?
  • 1 Post By stani
Discuss 3/4 Brass coupling with nylon thread, why? at UK Plumbers Forums; Hi all, I recently got with a pressurised water heater connections consisting of 3/4 brass nipples and brass couplings, the coupling has rubber seals and nylon internal thread, why would ...
    Sep 2016
    Question 3/4 Brass coupling with nylon thread, why?
    Hi all, I recently got with a pressurised water heater connections consisting of 3/4 brass nipples and brass couplings, the coupling has rubber seals and nylon internal thread, why would this be the case and can I not just directly couple to the water heater without the coupling supplied using 3/4 elbows to the water heater with the nipples fitted? What is the purpose of the supplied coupling? (attached photo)
    Attached Thumbnails Attached Thumbnails 3/4 Brass coupling with nylon thread, why?-viber-image.jpg
    SimonG's Avatar
    16,113
    Default Re: 3/4 Brass coupling with nylon thread, why?
    So you dont damage the heater by riving on the fittings.
    Mar 2012
    Bolton
    2,097
    They're dielectric couplings, they help prevent corrosion in the heater.
    If you don't fit them your warranty will be worthless.
  4. The Following User Says Thank You to JCplumb For This Useful Post:
    Sep 2016
    I should perhaps clarify it is the nipple that is designed to first connect to the water heater then the coupling into that, if I can connect direct to the nipple with an elbow (and this would be the preferred way due to space constraints) then I don’t need the brass/nylon coupling?
    In reply to SimonG (thank you) surely the heater protected from damage by the nipple? Correct me if I'm wrong.
    manchester
    2,357
    Jcplumb is absolutely correct and the warranty is worthless without them.
    Sep 2016
    JC yes that sort of makes sense to me as it looked like it was designed for electrical isolation (albeit water is a conductor) having said that I'm using PVC covered aluminium pipe and it would suite a lot better if I could use the supplied coupling a couple of metres from the tank as opposed to directly onto it, would it make any difference... in your opinion?
    manchester
    2,357
    It's not for electrical insulation it's to stop corrosion caused by dissimilar metals.
    quality likes this.
    manchester
    2,357
  10. The Following User Says Thank You to stani For This Useful Post:
  11. #9
    Sep 2016
    Advise duly taken they will be fitted, many thanks to all that replied
  12. The Following User Says Thank You to Plumb Duff For This Useful Post:
  13. #10
    9,993
    To be fair them ones look decent ones, normally there a bit of formed plastic just normally bin them as the tails out the heaters are plastic any way :s so no need and they always break/ snap as they can't take the heat and cooling
    Ariston water heaters
    also are you G3 registered as any pressurised water heater needs to be installed by a G3 qualified person
  1. Replies: 10
    Last Post: 17-09-2014, 07:51 PM
  2. Cross threading nylon thread
    By billybob150811 in forum Plumbing Forum
    Last Post: 01-08-2012, 11:25 PM
  3. 1/2 inch nylon tap washers
    By Essex Mark in forum Plumbing Forum
    Last Post: 21-11-2010, 06:44 PM
  4. Help identifying Shower Nylon Wheels please
    By kennybear in forum Bathrooms, Showers and Wetrooms
    Last Post: 03-02-2009, 03:41 PM
