Results 1 to 12 of 21
Plumbing & Plumbers Forum - PB versus Pex, something not quite right
Like Tree6Likes
Discuss PB versus Pex, something not quite right at UK Plumbers Forums; I am converting a stone barn with 4 washrooms to fit and a remote boiler ( 3 Ph electric due to an abundance of solar power) I intended to fit ...
    Aug 2016
    Question PB versus Pex, something not quite right
    I am converting a stone barn with 4 washrooms to fit and a remote boiler ( 3 Ph electric due to an abundance of solar power) I intended to fit a hot water loop system, however on aquiring the required PB barrier pipe (polyplumb) i find that the application notes for this product say under no circumstances should this be used for this type of installation. So not being one to take this lying down I started digging a hole! first i spoke to polypipe to ask why? they said it was due to the oxygen content of the hot water being constantly circulated would over time strip away the barrier layer??? This sounded a little off so decided to speak to WRAS and ask if this also applied to Pex? they couldn't comment however in the course of the conversation it became apparent that WRAS approval for polypipe was originally for cold water use and that the approval for hot water had been achieved by a work around using Bs 7291 part 1 2 or 3. The WRAS approval expired in august and to date, no application has been made for re-approval, for either cold water use or for hot water use which would require a lengthy testing.
    Apart from this though, My question/concern is that my understanding is that Pex is also approved under BS7291 part 1,2 or 3 and also would not be suitable under this for use in hot water loop circuits yet many suppliers of Pex and PB are saying Pex is o/k
    WHAT IS GOING ON HERE?
    SimonG's Avatar
    16,112
    Default Re: PB versus Pex, something not quite right
    Rural barn? Plastic pipes and mice dont mix.
    Secondary returns not to be done in plastic. Manufacturers say no, so do at your own risk.
    rpm and steveb like this.
    2,029
    Quote Originally Posted by windycol View Post
    Manufacturers test to their own standards and industry standards.
    Their own may exceed Industry.
    If a manufacturer says it's OK for recirculating, then it must be.
    Who have you found that say it can be used.?
    Speedfit
    Polypipe
    Marley
    Uponor
    Pipelife
    Wavin
    All the above are part of the Plastic Pipes Group, say not suitable.
    Chalked's Avatar
    3,922
    No pex or PB will allow circulated hot water. Only Uponor q&e is suitable.
    As above though, mice love pex and PB. Why not use copper?
    2,029
    From here;
    https://www.google.co.uk/url?sa=t&rc...x36DDQ&cad=rja
    Uponor MLC & Secondary circulation.
    Secondary circulation is classified as a system that:
     Provides potable hot water
     Maintains a temperature in excess of 65°C
     Replenishes water used in outlet with fresh water (oxygenated water) .
     Is a pumped circulation system.
    If all four of the points are covered your system is classified as a secondary circulation system (or recirculation system). Plastic pipeworks manufactured under BS-7291-1/3 2010 cannot be used in secondary circulation applications. Uponor MLC pipe can be used in secondary circulation because it is manufactured under a different standard (BS EN ISO 21003-1 2008) also because of the aluminum layer within the pipework it has a higher tolerance than a standard PEX pipe system. Although there still should be appropriate water temperature control on the system to ensure the water temperature does not exceed 70°C as stated in our guidelines.
    Chalked and tolly like this.
    Jun 2013
    1,781
    Why is it that some of these pipe brands can be used for heating systems, circulating at the same or higher temperatures and not be a problem.
    As for Uponor pipe stating that the temperatures should not exceed 70 C, well that's barely above the temperature requirements for prevention of Legionella.
    Not sure what your regs state, but ours state, the circulation temperature should be a minimum of 65 C.
    I wouldn't use a product that gives the supplier a 'get out of gaol card' over a 5 C clause.
    2,029
    Quote Originally Posted by oz-plumber View Post
    Heating systems cycle On /Off so the pipe isn't constantly at high temperatures, even in the UK
    Uponor;
    Heating systems and fan coil installations where the water temperature does not continuously exceed 80oC, or momentarily exceed 95oC (no more than 100 hours a year), and maximum operating pressure of 10 bar. Also, the system must be installed with room and water temperature controls in accordance with the current Building Regulations Parts L1 (Energy – Dwellings) and L2 (Energy – Non Dwellings) for England and Wales, or an equivalent national standard for Scotland or Republic of Ireland.
     Hot water services installations where the water temperature
    does not continuously exceed 70oC, or momentarily exceed 95oC (no more than 100 hours a year), and maximum operating pressure of 10 bar.
    Masood's Avatar
    East London / Essex border
    4,824
    Quote Originally Posted by snowhead View Post
    Plus CH primary water will eventually de-aerate. It's oxygenated water that creates problems for plastic pipe...
    Find us at:
    rpm
    rpm is online now
    Member rpm's Avatar
    Wherever I lay my hat
    7,958
    Having seen what small mice can do to plastic pipe I wouldn`t risk it.
    Aug 2016
    Cos copper doesnt come in 50metre coils at 28mm diameter that's why!
    SimonG's Avatar
    16,112
    Your putting a 28mm secondary return in?
    9,984
    O God get a plumber in unless it's a swimming centre or a small hospital you won't need a src that big
  1. Old fart versus new technology
    By mountainman in forum Gas Safe Register Forum - Public Forum
    Last Post: 18-10-2012, 08:50 PM
  2. Magnaclean versus TF1
    By mountainman in forum Central Heating Forum
    Last Post: 17-07-2012, 02:35 PM
  3. PTFE versus Loctite
    By antonm919 in forum Plumbing Forum
    Last Post: 24-04-2010, 10:14 AM
  4. Power shower versus TV
    By Plumbstar Tom in forum Bathrooms, Showers and Wetrooms
    Last Post: 11-03-2010, 05:10 PM
