Page 2 of 2 FirstFirst 12
Results 13 to 21 of 21
Plumbing & Plumbers Forum - PB versus Pex, something not quite right
Like Tree6Likes
Discuss PB versus Pex, something not quite right at UK Plumbers Forums; Originally Posted by windycol Cos copper doesnt come in 50metre coils at 28mm diameter that's why! Do what you like then! What do we know.?...
  1. #13
    Chalked's Avatar
    3,810
    Default Re: PB versus Pex, something not quite right
    Quote Originally Posted by windycol View Post
    rpm and Riley like this.
  2. #14
    Mar 2008
    513
    I've been led to believe that plastic is ok for a return loop provided the system isn't running continuously , ie it's on a timer so it's only running at intermittent times.
  3. #15
    9,661
    Quote Originally Posted by NickH View Post
    No no only copper, q and e or mlcp
  4. #16
    Aug 2016
    Abandoned secondary return, now going with straight delivery. Mice shouldn't pose a problem as the pipes will be in a dedicated insulated structure buried in the ground /concrete floors of the main building. I have never experience mice damage on any of the electrics/pipework i have dealt with over the last 30 years. I would think there would be less likelyhood in the countryside than an urban environment as field mice tend to be smaller than the normal domestic variety and don't struggle to find natural foods etc. With older town properties having timber joist floors I could imagine this might be an issue. Rats might be more of an issue in urban areas as it has been found that you are never more than 5 metre from one!
    This barn conversion is a total rebuild internally with solid floors and modern fully insulated structures above with attention being given to voids and cavities. so not envisaging a problem!
  5. #17
    9,661
    Depending on run / run off times of hot water you may need one
  6. #18
    Riley's Avatar
    Sarf Coast
    6,384
    Thing is you've asked for help and gone with what you want anyway even when we're telling you from Our experience it's not a good idea, but you obviously know better
  7. #19
    Aug 2016
    Sorry don't understand the point you are trying to make here, as because you have all advised that loop was not a good idea, i have reverted to a straight feed of the hot water to the bathrooms and not looping it back though for the life of me i cannot see that the effect on the pipework will be any greater in a direct feed than it would be in a controlled loop!
  8. #20
    Riley's Avatar
    Sarf Coast
    6,384
    I was really making reference to the insistence on using plastic when you would be susceptible to wildlife. I have seen it loads of times in rural areas
  9. #21
    9,661
    The reason we said no is the size doesn't need to be the same size as your main hot circuit
    And s lot once that length has cooled down you need to draw all the cold water off before you can get hot with a src this is minimal
  1. Old fart versus new technology
    By mountainman in forum Gas Safe Register Forum - Public Forum
    Last Post: 18-10-2012, 08:50 PM
  2. Magnaclean versus TF1
    By mountainman in forum Central Heating Forum
    Last Post: 17-07-2012, 02:35 PM
  3. PTFE versus Loctite
    By antonm919 in forum Plumbing Forum
    Last Post: 24-04-2010, 10:14 AM
  4. Power shower versus TV
    By Plumbstar Tom in forum Bathrooms, Showers and Wetrooms
    Last Post: 11-03-2010, 05:10 PM
