Page 1 of 3 123 LastLast
Results 1 to 12 of 26
Plumbing & Plumbers Forum - Desperate help needed
Like Tree15Likes
Discuss Desperate help needed at UK Plumbers Forums; Hi guys, for about a month or so now we have had a really bad smell in our house - it seems to start in the kitchen and bathroom on ...
    Aug 2016
    15
    Default Desperate help needed
    Hi guys,
    for about a month or so now we have had a really bad smell in our house - it seems to start in the kitchen and bathroom on one side of the house (We have two bathrooms and the smell never seems to go in the second one).
    Now it's really hard to pinpoint where it's coming from, or why because it's there sometimes and not others. Generally speaking it's lingering first thing in the morning, and seems to be most common when we are running hot water (After showering or after washing dishes). Also it changes from stagnant water smell to rotten egg smell (although since we've had the septic tank emptied it's far more stagnant water smell than eggs)
    We just had a new boiler installed just before Christmas 2015 so I can't see it being the central heating, even though coincidentally it seems to be whenever we are running the central heating.
    The other thing we just found out (As we live in a private let) is that the home is serviced by a septic tank. Now we have just paid through the nose to have this emptied thinking that must be the problem, and yet the smell is still here.
    So far we have done the following:
    Used expensive foam-drain cleaner down all the plugholes in the house (Pre-septic tank emptying, this was a day or so before we even knew we had a septic tank)
    checked all the kitchen appliances for dead rodents etc (As we live in the country so thought it could have been a dead mouse somewhere)
    Checked the tray at the back of the fridge, but there is nothing there, it was totally dry when we looked
    checked the waste hose of the washing machine and put it through a service wash with cleaner
    Now the kitchen and bathroom that has the smell is on the same side of the house as the septic tank so is it just a normal thing? I've never had a septic tank before, but we've lived here a year now and the smell has just started so surely something has gone wrong somewhere?
    Any advice would be greatly appreciated. The landlord does NOT like paying out for things to be done so we want to narrow it down and try and sort it ourselves before we bother her with it.
    Many thanks in advance!
    Aug 2016
    Herts
    Default Re: Desperate help needed
    Check that use of one item ie sink, bath,toilet flush, does not pull water out of another trap which will allow for foul smell into property.
    I have not worked on septic tanks ,but if tank is not vented then a possible build up of gas in tank could bubble up through traps.
    Anyone else have any thoughts - As a Gasman please correct me if I'm off track
  3. The Following User Says Thank You to Voidbetween For This Useful Post:
    lame plumber's Avatar
    Nov 2012
    North Devon by the sea
    15,667
    septic tank means in the sticks means dead rat under the floor is highly likely, leave it another 2 weeks and the smell will go once it has dried out.
    www.jcdheating.co.uk
  5. The Following User Says Thank You to lame plumber For This Useful Post:
  6. #4
    Forum Thug
    croppie's Avatar
    23,822
    A crispy critter doesn't smell that much, the moist ones do.
    If you're out in the sticks you'll soon be able to tell the difference between a corpse and various other whiffy pongs.
    Croppie
    (By the way, I'm commercial!)
  7. The Following User Says Thank You to croppie For This Useful Post:
  8. #5
    Aug 2016
    15
    Bleh - moist critters... I do have two cats, so a dead rat/mouse somewhere could be an answer and we also have a house that is raised.
    In regards to the 'traps' is this something in the plumbing and is it something I can change or something I would be best getting a plumber out for?
    Many thanks guys, I appreciate it
  9. #6
    Nov 2012
    15,667
    I once lobbed a fox I shot (it had murdered all our chickens and geese) into a ditch near an annoying neighbour, he called out dynarod every day for a week a few days on have you upset any neighbours recently?
  10. #7
    Aug 2016
    15
    Haha no, not that I know of. I am convinced something must be wrong somewhere as we've been here a year and it's only just cropped up now.
    There is a little door that leads to a cellar underneath the kitchen, it has some water from local flooding in Jan/Feb time sitting - not terribly deep, but I can't see how that would be making the smell unless there is something dead in it. I really don't want to siphon it out and thought it would just dry up on it's own.
    I will persevere though and keep hunting - if I turn up the culprit I'll be sure to let you know!
  11. #8
    Nov 2012
    15,667
    dry rot stinks, got any fungus popping through the floor boards
  12. #9
    Chalked's Avatar
    3,928
    Could be coming from a vent on the drain. Look at the top of a external soil pipe.
    In normal circumstances, septic tanks don't smell. But if they need emptying or the bacteria has stopped working' they can seriously pong!
    I would get it checked out by a company who empties them. It might need restarting.
    Ps what type of detergents are you using. Some can kill the process.
  13. #10
    Aug 2016
    15
    Hi there! We just had it emptied and I did ask the guy if all was ok (As I was using bleach because we didn't know we bloody had one in the first place!). He said all looked fine. There is a drain in our back garden for it, but they checked that too and it all seemed fine.
    I have however noticed today that the boiler pressure is on '0' and am now wondering if there is a problem in the system somewhere (the info on the boiler lid says that it could indicate a leak??).
    I've also bought some enzyme sticks for the drains, but we've not had this problem in all the time we were living here, even before we knew we had a septic tank. It was only because we noticed a bad smell we emailed the landlord who then saw fit to tell us we had a septic tank and it might need emptied.
    I'm really worried there is something broken in the house somewhere causing it!
    As to dry rot I can't see any fungus coming through those two rooms - one has linoleum stuck down and sealed around the edges and the kitchen is a tiled floor?
  14. #11
    Forum Thug
    croppie's Avatar
    23,822
    Just top up your boiler pressure to about 1 bar cold. As long as all your traps are holding water and none of them gurgle when any other sinks or loo's are used I would say it's unlikely to be them.
    Wet rot doesn't smell the way you've described but stagnant water does, I should get as much of it out as you can.
    But I'm still going for a floppy moist corpse......
    Croppie
  15. #12
    Aug 2016
    15
    Haha your preoccupation with corpses might need some attention :P I swear my fiance is still alive and breathing for now, although this far out in the country I wouldn't put it past something to be lurking somewhere!
    croppie likes this.
  1. Desperate for help
    By Suz in forum Plumbing Forum
    Last Post: 10-05-2014, 10:10 PM
  2. Desperate help needed :(
    By Nadine Berry in forum Plumbing Forum
    Last Post: 06-04-2014, 10:07 AM
  3. please desperate
    By debbie in forum Central Heating Forum
    Last Post: 14-02-2013, 01:01 AM
  4. Desperate help needed.
    By rocketmanbkk in forum Plumbing Forum
    Last Post: 30-04-2011, 12:33 PM
  5. I am desperate
    By leanne in forum New Member Introductions
    Last Post: 27-01-2010, 07:58 PM
