Go Back   Plumbing Forum | Plumbers Forums | A forum for plumbers in the UK > Plumbing Forums > Fittings & Pipes
Old 27-07-2008   #1 (permalink)
Ian K
View Ian K's Photo Album
Default Bath Pipes
I am a relative novice to plumbing can someone advice me on the following? I am replacing a bath which has a 15mm cold feed and a 22mm hot feed.I want to fit a monobloc bath filler but the tap tails are 15mm.Can I use a reducer to connect the 22mm to the 15mm pipe or will it affect the water flow?It is a gravity system usual cot water tank in loft hot water tank in cupboard
Ian K is offline   Reply With Quote
Old 27-07-2008   #2 (permalink)
ajs heating
Posts: n/a
Default Re: Bath Pipes
i would check the working pressure of the monobloc tap first as 15mm tells me it needs a working pressure of 1 bar.
which will be no good on a gravity system.
Old 27-07-2008   #3 (permalink)
Ian K
AJS- The taps have a min water pressure of 0.2 bar and a maximum of 0.8 bar.
Old 27-07-2008   #4 (permalink)
ajs heating
Posts: n/a
thats ok
i know your hot is gravity fed and 22mm just reduce down to 15mm.
is the cold gravity or mains ?
Old 27-07-2008   #5 (permalink)
Ian K
ajs The cold is mains fed.Does it matter where along the pipe I reduce? The bath filler comes with 15mm copper tails
Old 27-07-2008   #6 (permalink)
ajs heating
Posts: n/a
try keep it as much 22mm as you can.
Old 27-07-2008   #7 (permalink)
Ian K
ajs thanks very much
Old 05-08-2008   #8 (permalink)
Spirit
View Spirit's Photo Album
If the cold is mains and the hot is gravity, you must fit a double check valves to prevent cross contamination.
Spirit is offline   Reply With Quote
Fixing bath to wall Chris R Sanitary Ware 16 10-11-2008 07:17 PM
Open Question: Want to swap bath taps for bath shower mixer taps...? RSS Feeder Plumbing Questions 0 22-10-2008 03:48 AM
Lead waste pipes ferdon Plumbing Forum 4 18-08-2008 08:56 AM
Threading steel pipes plumbbobpete Plumbing Forum 2 31-07-2008 07:59 PM
Open Question: How do I fix a free standing lightweight clawfooted bath to a tiled fl RSS Feeder Plumbing Questions 0 31-07-2008 11:05 AM
