Chatrooms
Belfast Sink outlet with 4" flange -
Go Back   Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK > Plumbing Forums > Fittings & Pipes
Notices
Old 03-02-2010   #1 (permalink)
WHPES
Info
Default Belfast Sink outlet with 4" flange
Hi. looking for a sink waste with a 4" flange to fit a low type brown saltglazed sink.
Standard Belfast Sink waste is too small and won't grip.
Anyone know where I can get one?
WHPES is online now
Old 05-02-2010   #2 (permalink)
oap67
Info
Default Re: Belfast Sink outlet with 4" flange
maybe a basket strainer waste., or a urianal waste.
Richard
oap67 is offline
Old 05-02-2010   #3 (permalink)
stevetheplumber
Info
the waste for these old sink were made on site out of lead with a grill on the inside and jointed with putty not very pretty even then
stevetheplumber is offline
Old 05-02-2010   #4 (permalink)
WHPES
Info
I've seen them made from brass, sometimes incorporating a bell trap, but nothing like that avilable now. Basket strainer will do the job but I need a longer bolt due to thickness of the sink base. Urinal waste won't take a plug so no good.
WHPES is online now
Old 4 Weeks Ago   #5 (permalink)
mikejcalder
Info
Unhappy Re: Belfast Sink outlet with 3" flange
Hi, I'm Mike and i am also about to have trouble with an outlet on an old Shanks Belfast sink. I had to destroy the old waste which comprised a slotted bronze 2" id outlet as it was enclosed in the 3" lead outlet piping ( which was leaking elsewhere). I don't believe the more copmmon standard 1.5" 'Traditional' belfast waste will fit as the outlet on the base ceramic is some 3" id. Also the depth of the outlet is at least 60mm so I don't believe the standard 70mm deeep waste outlet will be sufficient to take securing flange/nut together with attachment to any new waste piping. My searches of the internet so far are only producing the standard 1.5 " outlet unit. Has anyone come across this problem before and if so what did they use to solve it other than buying a new belfast unit. cheers mike
mikejcalder is offline
Old 4 Weeks Ago   #6 (permalink)
Blackcatgas
Info
Default Re: Belfast Sink outlet with 3" flange
Quote:
I had a local engineering company spin me a alloy floor gully cover up to replace the missing obsolete one in Walkabout bar Broad street Birmingham, cost £70 though and that was back in 2001.
Blackcatgas is offline
Old 3 Weeks Ago   #7 (permalink)
WHPES
Info
Basket waste worked fine for me. Needed to get some brass threaded bar and a brass nut in place of the bolt which it is supplied with as this is not long enough for the thickness of the sink. Suggest you try the same.
WHPES is online now
belfast sink in bathroom frugal Sanitary Ware 5 22-01-2010 10:25 PM
blocked sink... shaneo85 Plumbing Forum 15 10-12-2009 12:21 PM
Sink to Waste Trap fitting? arthway Plumbing Forum 5 25-11-2009 11:53 AM
