Results 1 to 1 of 1
Plumbing & Plumbers Forum - Newbie help - shower feed size etc
Discuss Newbie help - shower feed size etc in the Fittings & Pipes at Plumbers Forums; Hi all, i'm moving the bathroom from downstairs to upstairs and need a few professional pointers I've read that bath 'fillers' and showers should have a 22mm feed, how important ...-
06-09-2009 #1New to Plumbing Forum
- Sep 2009
I've read that bath 'fillers' and showers should have a 22mm feed, how important is this?
I'm not too bothered about the bath but the shower i want to give it the best chance.
The hot water tank/cylinder is on the same lever as the new bathroom and the cold tank is in the loft, all be it on the floor so i may need to lift that up to increase pressure?
My questions are.
The shower mixer i have is gravity fed and has 15mm connections so my questions are.
1.Should i just run 15mm pipe to the shower or run 22mm and then reduce it almost at the actual shower, the reason i was thinking this was because would it retain more flowrate and pressure?
2. If to go for just 15mm feed would i be able to take the feed for shower hot from the general hot feed in the bathroom ie. same pipe feeding sink, bath and shower, i would it be better for the shower to have its own feed (both hot and cold)
I'm going to instal it so that i can easily add a pump if needed but i'd prefer not to due to cost.
Any info/advice/pointers would be great and i'll thank anyone now in advance, i will just mention thought that i currently have no internet connection so i wont be on here again until midweek probably so please bare with
Many thanks all
Gav
Also, sorry if this is a repeated thread, i've read alot of threads in the shower/wetroom but none seem to fully answer my questions,
Thermostatic shower - no cold feed
By joannep in forum Plumbing ForumReplies: 3Last Post: 29-08-2009, 10:52 PM -
Thermostatic shower questions
By badbob in forum Plumbing ForumReplies: 1Last Post: 14-06-2009, 06:28 AM -
Shower Debacle
By DarrenTad in forum Plumbing ForumReplies: 4Last Post: 24-04-2009, 07:33 PM -
Shower Pump Fit to shower pipes only
By DazJWood in forum Bathrooms, Showers and WetroomsReplies: 0Last Post: 07-03-2009, 07:39 PM -
What size cold feed pipe to a Direct HW system
By NYKLEE in forum Plumbing ForumReplies: 1Last Post: 01-02-2009, 01:22 PM
Low Loss Header Help Needed Please
3 Minutes Ago in Central Heating Forum
