Plumbing Forum Plumbing Forum Plumbing Forum Plumbing Forum Plumbing Forum
Plumbing Forum | Plumbers Forums | A forum for plumbers in the UK Plumbing Forum Sponsorship Armadillo Workwear for Plumbers Drill Tough Objects Plumbing Forum Sponsorship
Plumbing Forum | Plumbers Forums | A forum for plumbers in the UK » Plumbing Forums » Fittings & Pipes
Old 01-04-2008   #1 (permalink)
a9blue
Default Soldering problems
I have a new butane/propane torch with a fine flame. I cant use it with solder ring fittings because no matter what I try the solder doesnt appear at the joint. Can anybody help?
a9blue is offline   Reply With Quote
Old 01-04-2008   #2 (permalink)
mighty-metal
Default Re: Soldering problems
It appears to me the torch you are using is not producing enough heat to melt the solder.
Remember copper is a very good conductor of heat. Get a bigger torch.
mighty-metal is offline   Reply With Quote
Old 09-04-2008   #3 (permalink)
Matty A
I bought the rothenberger quick fire and works really well the flame almost wraps around the fitting thus heating all the way round and getting even soldering.
Old 10-04-2008   #4 (permalink)
ProffesorPlumb
Monument do a good piezo burner head that will fit most Propane / MAPP cylinders.
Model number 3440c
You may post new threads
You may post replies
vB code is On
NO Central Heating and NO Hot Water problems nabs2007 Central Heating Forum 9 01-12-2007 07:39 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
