Results 1 to 6 of 6
Plumbing & Plumbers Forum - Philmac lead to copper
  • 1 Post By snowhead
Discuss Philmac lead to copper in the Fittings & Pipes at Plumbers Forums; Got a lead pipe to connect to under a bath and want to try a Philmac transistion coupler instead of a ledlock as I don't entirly trust leadlocks. This is ...
    Apr 2008
    West Yorkshire
    2,033
    Default Philmac lead to copper
    This is a gravity hot feeding bath and basin, I've used Philmac only on MDPE x MDPE and I'm confused about which fitting Philmac connects 3/4" 9lb lead to 22mm copper.
    Is this the one?
    Philmac MDPE UTC Repair Joiner | Philmac MDPE UTC Repair Joiner 21-27mm x 21-27mm | City Irrigation Ltd
    Koogatubac's Avatar
    Jan 2011
    1,209
    Default
    Why dont you trust leadlocks? Used them before any never had any problems
    Apr 2008
    West Yorkshire
    2,033
    Default Re: Philmac lead to copper
    Don't get me wrong I've used them aswell and still have every size in the van but don't like the way the lead can be waggled out of the fitting and this is a customer who is paranoid about leaks.
    Koogatubac's Avatar
    Jan 2011
    1,209
    Default
    Whatever works for you mate just like to know other opinions best in luck finding a right alternative
    Jan 2008
    North Yorkshire
    4,149
    Call Philmac customer services for advice.
    Personally Philmac fittings are all I have ever used. Our local merchants doesn't do leadlocks anyway so never used one myself.
    655
    3/4 9lb lead is 30mm o.d.
    The fitting you linked (27mm) is too small, unless you shave the lead.
    Technical catalogue, half way down;
    http://www.philmac.co.uk/literature/...ngs-brochures/
    steveb likes this.
  1. Copper to lead.
    By Easy peasy in forum Plumbing Forum
    Last Post: 08-07-2012, 08:41 PM
  2. Lead to copper joints
    By Centralheatking in forum Plumbing Forum
    Last Post: 25-01-2011, 01:56 PM
  3. Lead to copper!
    By wombat in forum Plumbing Forum
    Last Post: 31-12-2009, 12:09 PM
  4. copper to lead (gas)
    By a9blue in forum Plumbing Forum
    Last Post: 08-02-2009, 10:44 PM
  5. Lead Lock, joining copper to lead
    By alex in forum Plumbing Forum
    Last Post: 14-04-2008, 06:35 PM
philmac lead to copper
philmac lead
ledloc fittingswhat size philmac for leadneed to know lead pipe bore before using philmac couplingsphilmac coupling for leadphilmac lead-lok lead to copper fittings
