Chatrooms
Strange coupling for antique sprinkler -
Go Back   Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK > Plumbing Forums > Fittings & Pipes
Notices
Old 03-07-2009   #1 (permalink)
madmart
Info
Default Strange coupling for antique sprinkler
Can anyone tell me where I might get a coupling to fit the one in the attached picture?
It belongs to a cricket club who had their hose stolen and now need to replace the part that was on the stolen hose.
Thanks for any help and reading this post.
madmart is offline
Old 03-07-2009   #2 (permalink)
unguided1
Info
Send a message via Skype™ to unguided1
Default Re: Strange coupling for antique sprinkler
Hi madmart
have yougot any dimensions, because that looks a bit like a compressor air hose connector, so you could try a hire shop.
regards
Mike
unguided1 is offline
Old 04-07-2009   #3 (permalink)
madmart
Info
Thanks for the advice Mike.
It measures 1.5" and I have uploaded a better image.
Regards,
Martin
madmart is offline
Old 05-07-2009   #4 (permalink)
Bernie2
Info
Yes sure looks like compressed air line bayonet twist lock fitting.
Try hire shop as mentioned or anywhere that sells pneumatic drills or compressors. Looks a lot like an air hose off a pneumatic road drill which uses about 100psi pressure, so its heavy stuff.
It may be a bit on the heavy side for a normal tool hire shop,you may have to look around for one.
Food Fortune!
Bernie2 is offline
Old 06-07-2009   #5 (permalink)
stevetheplumber
Info
defo air line coupling probably chraper to change the valve unless you need large bore hose
stevetheplumber is offline
Old 10-07-2009   #6 (permalink)
madmart
Info
Cheers Guys,
Went to the local hire shop and showed them - it was indeed an air coupling.
Your advice and time is greatly appreciated.
Martin
madmart is offline
