Hi
Whether or X and Z dimensions are used in the real world or not i am afraid they are in the 6129, here is an explanation i gave to another thread about the same topic
The x dimension is used for copper, push fit, soil and waste fittings and the z dimension is used for low carbon steel.
To find the x dimension measure the fitting from the centre to the end where you insert the pipe, then insert the pipe fully to the stop and mark on the pipe where the pipe meets the fitting. measure the amount of pipe that is inside the fitting and subtract that from the measurment of the centre to the end the figure you are left with is the x dimension.
Similar way to find the z dimension apart from the fact there is no pipe stop in LCS fitings, so you use the insertion depth. For example on 15mm LSC the insertion depth is 13mm so you take that off your fitting measurment and that leaves your z dimension.
Hard to explain this without the use of drawings but i hope this helps.
