Go Back   Plumbing Forum | Plumbers Forums | A forum for plumbers in the UK > Plumbing Forums > Fittings & Pipes
Old 09-11-2008   #1 (permalink)
nick penfold
View nick penfold's Photo Album
Default x-dimensions and inset depths of fittings
Hey all,
I'm in my 2nd year of a college course doing both my nvq and tech cert.
Now, at work, i have no problems with any pipework etc. At college i find most of it quite easy. However, everytime it comes to building your typical frame in copper, plastics or LCS i seem to get the measurements out by about 2 or 3 mm.
Trust me, when i made the copper frame in the first year, i had to make it again about 6 times.
Im kinda wondering am i measuring wrong? i understand what the x dimension is and normally measure the inset depth by putting a piece of pipe in the fitting, marking off then removing and measuring the distance.
Kinda had the same issue with the plastic hep type stuff. im guessing that could be due to the inserts in to the pipe extending its length.
Is there a set technique to measure this x-dimension and inset depth?
is there any tech docs out there giving basic x-dim's for all the different makes of fitting?
did or does anyone else struggle with this at college?
i don't believe i should be having such trouble with this but for whatever reason i am.
Any enlightenment from the old hands or peeps still at college would be greatly recieved.
Nick
nick penfold is offline   Reply With Quote
Old 13-11-2008   #2 (permalink)
migoplumber
View migoplumber's Photo Album
Default Re: x-dimensions and inset depths of fittings
if you need to worry about 2-3mm for your college work, then you might be best asking your tutor for some more advice. sounds like your doing everything fine and in the real world 2-3mm is nowt to worry about. good luck
shaun
migoplumber is offline   Reply With Quote
Old 13-11-2008   #3 (permalink)
johnmcginty
View johnmcginty's Photo Album
All fittings are different , if you are referring to how much pipe goes in the fitting, or the z measurement which is taken from the exact middle to the beginning of the pipe it is usually the exact measurement of the pipe eg 15 mm z measurement is 15 mm on a pushfit! When you do this in the real world you wont use the same methods anyway so dont worry .
johnmcginty is offline   Reply With Quote
Old 18-11-2008   #4 (permalink)
dorset
View dorset's Photo Album
Hi
Whether or X and Z dimensions are used in the real world or not i am afraid they are in the 6129, here is an explanation i gave to another thread about the same topic
The x dimension is used for copper, push fit, soil and waste fittings and the z dimension is used for low carbon steel.
To find the x dimension measure the fitting from the centre to the end where you insert the pipe, then insert the pipe fully to the stop and mark on the pipe where the pipe meets the fitting. measure the amount of pipe that is inside the fitting and subtract that from the measurment of the centre to the end the figure you are left with is the x dimension.
Similar way to find the z dimension apart from the fact there is no pipe stop in LCS fitings, so you use the insertion depth. For example on 15mm LSC the insertion depth is 13mm so you take that off your fitting measurment and that leaves your z dimension.
Hard to explain this without the use of drawings but i hope this helps.
dorset is offline   Reply With Quote
Old 19-11-2008   #5 (permalink)
fuzzy
View fuzzy's Photo Album
what ever happened to centre to centre and end to centre, thats much easier than giving it a fancy name like X dimensions
Old 19-11-2008   #6 (permalink)
nick penfold
cheers for the help peeps, i kinda understood the theory its just that i figured my measurements must have been off on the x dimensions. Got the frames completed no problems etc now. What i found interesting is that i have checked some of the other guys folders and had a look at the measurements they have put in for x dimensions etc and none are identical.
i thought it odd that if everyones x dimensions measurements were different by 3 or 4 mm in some cases then surely everybody would be cutting pipe to different lengths so surely their frames built at college would be of differing sizes (i.e. out by 3 or 4 mm).
And awwww crap LCS next
Old 22-11-2008   #7 (permalink)
Aqua Mechanica
View Aqua Mechanica's Photo Album
Don't worry, you're not alone, this is utterly infuriating. I made the frame to size, took a picture of myself with it and then measured it after taking the thing apart, lol
You're right, my measurements and everyone elses measurements were different, it's one of those strange anomylous things???
Once it's done, you'll never have to do it again, just think of it that way.
And the 2mm tolerance sucks. Nothing worse when you find one bit of the frame is 3mm out and the lecturer makes you take it apart.
A veteran lecturer would surely turn a blind eye if you could explain the principles of X and Z dimensions at that point and allow you to move on to the next task ;-)
Aqua Mechanica is offline   Reply With Quote
Old 29-11-2008   #8 (permalink)
ste b
View ste b's Photo Album Send a message via AIM to ste b Send a message via MSN to ste b
hi, just joined the forum today and very pleased to have dropped on this forum,i was looking for the specific measurments which you subtract from the copper pipe length in the x dimension, i completed the z dimension with lcs tube,what a bloody nightmare i had searching for that,struggled a bit to work that one out then it all fell into place when the lecturer gave us a sheet with all the dimensions of the fittings which gave us exact size and what to subtract from the pipe length (3/4 and 1/2 inch),i am currently working on the x dimesion and was wondering if anyone knows where i can get hold of a referance sheet with all these fittings sizes........i dont have any fitting at home to measure,but i do have the fitting list.....cheers for any info and look forward to passing on any info which i can.
ste b is offline   Reply With Quote
Old 29-11-2008   #9 (permalink)
Aqua Mechanica
I think the insert depths can vary, no one ever has the same measurements in their folder and when I got my lecturer to check my measurements for Z Dimensions last week he was looking for an answer between two measurements 4mm apart. (This may well be to accomodate the 2mm tollerance allowed)
Old 29-11-2008   #10 (permalink)
ste b
Cheers for the reply,appreciated,so the easiest thing to do is get the fittings and measure the distance required...........?
