Results 1 to 9 of 9
Plumbing & Plumbers Forum - compression rings on stainless steel.
Discuss compression rings on stainless steel. in the Fittings & Pipes at Plumbers Forums; Hello. I've contacted my college about this but they were about as much use as a fart in a spacesuit...so if anyone here can help..... When joining stainless steel pipe ...
    Plumbing Forum Contributor
    Jun 2010
    31
    Default compression rings on stainless steel.
    Hello.
    When joining stainless steel pipe what compression materials are a no-no and which are generally used? What are the olives made from and can anyone suggest a good supplier...I know there are probably electrolytic considerations but how relevant are they with stainless steel?..
    Any snippets of info, experiences would be appreciated.
    cheers
    quality's Avatar
    Sep 2009
    South Yorkshire
    2,436
    Default Re: compression rings on stainless steel.
    Try Swagelock for stainless compression stuff
    tamz's Avatar
    Scotland
    9,348
    I take it you just want to connect to existing stainless steel? Join using std brass compressions with BRASS rings. If you want a decent compression fitting use Kuterlites or Conex. The stainless will probably be imperial so you will need green rings for 3/4".
    No problems at all with them reacting.
    If it is for fitting new stainess? why would you unless speced for some process work, the merchants will supply stainless fittings to suit the tube.
    Jun 2010
    31
    ...thanks chaps..but it was no more than curiosity really..
    On the course it tells you that stainless was used in the 70's during a copper shortage and to join it you need to use either silver soldering or compression, but it doesn't go into it more than that. It got me thinking of the possibility of running into it on a future job and how i would work with it, what materials are used and what are forbidden and other questions that lead me to post this. I was also toying with the idea of having a go at plumbing my bathroom in with it and how reaslistic a proposal that would be...just info gathering really. The internet doesn't seem to answer these questions very well...
    cheers anyway.
    Feb 2009
    Liverpool
    1,972
    Actually!
    I think it was Yorkshire who sold a flux for stainless steel which you could use ordinary solder with.
    Usually though house basher's used bog standard Conex compression fittings with a bit of jointing paste or the now banned red lead paint.
    Jun 2010
    31
    So the general concensus is standard brass compression fittings but with a brass (not copper) ring. That yorkshire flux point is worth looking into, if it's still available then that's worth knowing.
    That's armed me with a bit more info. thanks for your posts.
    Any more experiences though, i'm all ears.
    tamz's Avatar
    Scotland
    9,348
    The flux used is phosphorus or borax based. Can't remember.
    Stainless was hard to work with. Hard to bend (with a stand up machine) and hard on your cutters (get special cutter wheels)
    Jun 2010
    31
    I'd heard something similar with regards to fabrication. I'd imagine it's a metal that would look nice in a bathroom with good longevity and easy to clean, if a little expensive. Could use chrome plated copper but where would the fun in that be...?
    thanks.
    Feb 2009
    340
    Quote Originally Posted by thebeatmeister View Post
    thanks.
  1. Compression reducing set on barrier pipe
    By system3 in forum Fittings & Pipes
    Last Post: 13-07-2010, 05:58 PM
  2. Compression fittings A or B
    By mrlennie in forum Plumbing Forum
    Last Post: 08-07-2010, 01:12 AM
  3. Metric to Imperial compression joint
    By easyt in forum Plumbing Forum
    Last Post: 03-07-2010, 02:03 PM
  4. Stainless steel pipe in domestic plumbing
    By dave1234 in forum Plumbing Forum
    Last Post: 26-06-2010, 07:54 PM
  5. galvanized steel pipe to copper fitting?
    By that bloke. in forum Fittings & Pipes
    Last Post: 23-04-2010, 11:21 PM
compression ring for stainless steel tube
machine to compression ring on stainless steeel pipe
can i use compression fittings on stainless steel pipe
can you use compression fittings on steel pipe
how do brass compression fittings work
stainless compression rings
can you use compression fittings for stainless steel pipe
