Results 1 to 9 of 9
Plumbing & Plumbers Forum - Recommend an external oil boiler?
Discuss Recommend an external oil boiler? at UK Plumbers Forums; We are installing central heating and will need an external oil boiler in the 20-28kw range. Can anyone recommend a make? We are tempted by the Grant Vortex: does anyone ...
    fishingscotland
    Default Recommend an external oil boiler?
    We are installing central heating and will need an external oil boiler in the 20-28kw range. Can anyone recommend a make? We are tempted by the Grant Vortex: does anyone have a view on them? Thanks for your help
    ecowarm's Avatar
    Mar 2010
    lincolnshire
    3,720
    Default Re: Recommend an external oil boiler?
    As an alternative have you looked at an air source heat pump?
    If you have to buy a tank and boiler it is a good alternative.
    If its designed and installed correctly.
    Apr 2009
    415
    Worcester 25/32 External are good boilers. Fitted loads and never had problems
    Dec 2009
    14
    Grant boilers are easy to fit, compared with a worcester
    fishingscotland
    Thanks all...thought about an air source heat pump, but it's by the sea, and even the stainless steel rots there.
    Worcester sounds good, but I'm sure our pumber would appreciate an easier fit with the Grant.
    How does the Grant measure up, in terms of reliability? Any thoughts, anyone? Thanks.
    quality's Avatar
    Sep 2009
    South Yorkshire
    3,641
    Grant every time for me
    May 2010
    west cork
    Hi All
    I do know grant boilers are stainless especially around condense area, were some other boilers use plated steel, if these take a knock during servicing, corrosion will start.
    Dec 2009
    869
    Hi motsky,
    Welcome to the forum, lets start as we mean to go on, do you seriously expect us to believe you're from West Cork when you didn't mention Firebird??????????
    Sorry O.P. a joke among the Irish probably only motsky will get it.
    Grant Vortex seven days a week twice on Sunday for me, while you don't hear about it now you will later, the Grant Vortex is one of the easiest condensing oil boilers to service, that as well as one of the highest SEDBUK ratings saves you money in the future.
    Another alternative you might consider if you have the room is the Grant Spira wood pellet boiler.
    Roger Welton's Avatar
    Dec 2011
    Somerset
    3,131
    Grant every time for me also.
    -edit to add though i gues the OP has already completed the work judging by the date
  1. External gas boiler
    By quattro64 in forum Gas Safe Register Forum - Public Forum
    Last Post: 05-04-2016, 07:49 PM
  2. Recommend replacement for Ikon (Glow-worm?) CI80 boiler
    By Ross666 in forum Central Heating Forum
    Last Post: 10-05-2013, 04:54 PM
  3. recommend me a boiler/system
    By g60rge in forum Central Heating Forum
    Last Post: 15-03-2012, 11:39 AM
  4. 40/42kw boiler. Which would u recommend?
    By Mbear in forum Central Heating Forum
    Last Post: 19-01-2012, 12:01 AM
  5. Which boiler to you recommend?
    By emlin in forum Central Heating Forum
    Last Post: 15-12-2011, 10:26 PM
  6. What make/ model of boiler would you recommend?
    By nuclearfusion in forum Central Heating Forum
    Last Post: 12-08-2010, 08:15 PM
  7. What boiler would you recommend???
    By cerpnjak in forum Central Heating Forum
    Last Post: 20-10-2008, 11:27 PM
  8. Central Heating Cover useless -'design fault'
    By robertai in forum Central Heating Forum
    Last Post: 14-06-2008, 08:33 PM
outside oil boilers reviews
external oil boiler reviews
external oil boilers any good
external boilers any good
best external oil boiler
