Results 1 to 6 of 6
Plumbing & Plumbers Forum - Noisy ch pump
Noisy ch pump
Discuss Noisy ch pump in the Central Heating Forum at Plumbers Forums; Scottish gas fitted a new condensing boiler into our ch system two years ago. We had problems with "rushing water sounds" when pump started and banging and knocking noises up ...-
08-05-2010 #1Jimbo the JamboGuest
Noisy ch pump
Scottish gas fitted a new condensing boiler into our ch system two years ago. We had problems with "rushing water sounds" when pump started and banging and knocking noises up until the pump was replaced last February. We were told to keep venting the radiators for a few days (it took some weeks), however when the pump starts up now it sounds like stones or grit flushing through. On sounding the pump with a long screwdriver between ear and pump body the noise is in the pump. On Friday Scot. Gas carried out a safety check and the gentleman said he thought it could be a stone/s but fixing it was not covered by my maintenance agreement. I fitted the ch system myself 28 years ago and have had little or no problems over the years, the last two have thrown up a succession of niggly problems, this one is annoying.
Any suggestions welcome.
Thanks (this is my first post),
jimbo
08-05-2010 #2Plumbers Arms member
- Jun 2009
- 753
- Thanked 22 Times in 22 Posts
Re: Noisy ch pump
power cleanse system
08-05-2010 #3Jimbo the JamboGuest
Re: Noisy ch pump
Thanks for the reply. Scot.Gas did that during boiler installation cost £500 for power flush.
jimbo
08-05-2010 #4Plumbers Arms member
- Oct 2009
- north wales, cheshire, shropshire
- 1,205
- 66
- Thanked 41 Times in 41 Posts
Re: Noisy ch pump
how old are the rads - they could be corroding from the inside.
08-05-2010 #5uɐɯ sɐƃ moderator
- Jan 2010
- maesteg,south wales
- 13,343
- 827
- Thanked 1,266 Times in 1,209 Posts
Re: Noisy ch pump
could be corrosion or cavitation if not a sealed system please clarify
GASMAN
08-05-2010 #6Jimbo the JamboGuest
Re: Noisy ch pump
Original rads 28 y.o. but sounding the pipes above and below the pump localise the noise (like broken ball bearings in a bike wheel) to the actual pump.
jimbo
Its an open vented system. Scot Gas fitted a magna-clean filter which seems to clean a lot of iron oxide out.
cheers,
jimboLast edited by Jimbo the Jambo; 08-05-2010 at 07:29 PM. Reason: Automerged Doublepost
Air in shower pump
By Alanka in forum Bathrooms, Showers and WetroomsReplies: 1Last Post: 08-03-2010, 03:28 PM -
Noisy heating pump
By Hogweed in forum Central Heating ForumReplies: 13Last Post: 19-01-2010, 10:03 PM -
Shower pump needed but tiling already done!
By tatty in forum Bathrooms, Showers and WetroomsReplies: 8Last Post: 16-11-2009, 09:00 PM -
Noisy pump
By deano76 in forum Plumbing ForumReplies: 3Last Post: 21-06-2009, 07:39 PM -
Separate pump in addition to the one included in the condensing boiler?
By hughs in forum Central Heating ForumReplies: 11Last Post: 10-02-2009, 06:28 PM
gas explosion in notts
