Results 1 to 9 of 9
Plumbing & Plumbers Forum - Old radiator output help
  • 1 Post By JohnWB
Discuss Old radiator output help at UK Plumbers Forums; I am going to replace an old radiator and I was wondering if anyone would have an idea what its output would be. It's a double 2.2m x 0.44m without ...
    Oct 2016
    14
    Default Old radiator output help
    It's a double 2.2m x 0.44m without any fins
    Last Plumber likes this.
    Mar 2013
    1,447
    Default Re: Old radiator output help
    Replace with 2.5Kw output at Delta 50 or a 3Kw which would approx 2.5Kw at Delta 40.
    Oct 2016
    14
    Quote Originally Posted by joni os View Post
    Thanks very much for that but I was really trying to find out the old radiator heat output
    Super Moderator
    steveb's Avatar
    Nov 2007
    hythe hampshire
    12,921
    it is very difficult to know without knowing the make because they aren't all made the same.
    The Turtle Moves
    10,005
    about 1kw for something like a roundtop etc
    Jan 2017
    14
    Whilst I take Steveb's point about it being different for different makes are they so different that any make wouldn't give a rough idea? I have done the same myself but found it difficult to get info on radiators without convector fins as not many seem to be sold now. I only needed single panel I haven't seen any data on double panel no convector fins (hence your post).
    Can you still buy the double panel without fins? I haven't seen any. Another approach if you cannot get them is to ask was this radiator sufficient when at it's best? If not or borderline get double panel with convector (check whether the pipework will reach it). If it was a bit much then a single panel with convector fins.
    The nearest size I found for your figures is the Stelrad 450x2200. The single panel single fin is 1690W at deltaT 50 and the double panel single fin is 2433W so yours was probably somewhere in between when new.
    Jan 2017
    14
    Jan 2017
    14
    wiki.diyfaq.org.uk contains a page on central heating radiators which might be helpful though it doesn't deal with double panel no convector.
    Last Plumber's Avatar
    Aug 2016
    Lancashire
    1,441
    Quote Originally Posted by JohnWB View Post
    It's around 7000Btu's/hr @ Delta 60 ( Ish, don't hold me to it but it's near as damn it for your needs )
  1. Ooooooold radiator output
    By Millsy78 in forum Central Heating Forum
    Last Post: 22-08-2013, 09:16 AM
  2. Help with radiator output needed
    By Best in forum Central Heating Forum
    Last Post: 11-08-2012, 01:37 AM
  3. radiator output
    By ggman in forum Central Heating Forum
    Last Post: 25-09-2010, 08:18 PM
  4. 2.34kw radiator output
    By egibberate in forum Central Heating Forum
    Last Post: 04-07-2010, 11:24 PM
  5. radiator output
    By micheal mack in forum Central Heating Forum
    Last Post: 15-01-2010, 03:59 PM
