Results 1 to 4 of 4
Plumbing & Plumbers Forum - Would you REALLY always recommend running UFH constantly?
Discuss Would you REALLY always recommend running UFH constantly? at UK Plumbers Forums; Been adding UnderFloor Heating to my own house and it's running provisionally. Controls yet to be wired. Can't think of ideal system but this is the best I can think ...
    Jan 2015
    Powys, mid Wales
    204
    Default Would you REALLY always recommend running UFH constantly?
    Been adding UnderFloor Heating to my own house and it's running provisionally. Controls yet to be wired. Can't think of ideal system but this is the best I can think of myself:
    Since the UFH is auxiliary to a radiator (theoretically not enough output from UFH to hold its own in cold weather), I decided to try plumbing the manifold (with pump, mixing valve assembly etc) with flow and returns from the heating circuit and room temperature control using the same stat that runs the central heating. Timber floors and spreader plates, so response time isn't too bad.
    Existing room stat is in the room heated by UFH - house is open plan and most of the heat goes upstairs anyway, but bedrooms do not overheat as they are controlled by TRVs and doors kept shut.
    Basically, the UFH will come on when everything else is on. The radiator will provide the main heat, and then the UFH will help keep the room and floor warm. In warmer weather, the radiator can be shut off using the manual control valve.
    I know it's usually advised to have the UFH on its own zone, but my thought is that all that will happen is that my old cast-iron-heat-exhanger-non-condensing boiler will cycle continually and reduce the system efficiency significantly (that would be an 8.5kW boiler running at 1.2kW demand... ) and heat losses from pipework would effectively heat the whole house to some degree anyway (centre terrace - so not a huge heat requirement) . The radiators in other rooms currently in use are just two - my bedroom (in practice, the TRV normally closes fully) and the bathroom (600Wish, but usually half-warm due to TRV).
    Also, days like today the windows can be open most of the day and it seems wrong to have heating on with open windows. Last three days heating has been on for an hour or two each evening and then I switch it off and sit by the fire instead.
    Does my reasoning about the UFH make sense to anyone else, given that I'll be the one using it? I know I'm weird, but I wanted a reality check when it came to system design.
    SimonG's Avatar
    16,035
    Default Re: Would you REALLY always recommend running UFH constantly?
    Just to confirm. Rads and floor come on together but you have thermostatic control on the floor water temperature?
    Chalked's Avatar
    3,810
    Will sort of work but your floor will slowly reach 60-70 degrees.!
    Jan 2015
    Powys, mid Wales
    204
    Some confusion. To clarify:
    Simon G: Correct - there is a thermostatic mixing valve on the UFH manifold and a floor sensor that will shut down the UFH if floor gets too hot.
    Chalked: There will be a thermostat set on the floor to limit the maximum floor temperature by closing the zone valve to the UFH manifold and shutting down the UFH pump. This will not switch off the rest of the heating system.
  1. Pump constantly running
    By Willknapo in forum Central Heating Forum
    Last Post: 15-01-2016, 10:31 AM
  2. Toilet Constantly Running
    By shauno in forum Plumbing Forum
    Last Post: 09-07-2014, 11:31 PM
  3. Salamander ESP 75 CPV running constantly ??
    By backfire in forum Bathrooms, Showers and Wetrooms
    Last Post: 30-05-2014, 01:07 AM
  4. Bosch 30 CDi Fan constantly running
    By pootle18 in forum Central Heating Forum
    Last Post: 21-07-2011, 09:41 AM
