Results 1 to 2 of 2
Plumbing & Plumbers Forum - glow worm hxi 30 boiler f9 fault code, what it means blown fuse on pcb main board
Discuss glow worm hxi 30 boiler f9 fault code, what it means blown fuse on pcb main board at UK Plumbers Forums; glow worm hxi30 boiler f9 fault code. no low water pressure switch on this boiler.and blown fuse second on pcb (does tis mean board gone?) main board pump external to ...
    Dec 2016
    Default glow worm hxi 30 boiler f9 fault code, what it means blown fuse on pcb main board
    pump external to boiler. grundfos 25-80
    slight history of job, arrived to fit dual fuel cooker gas hob electric oven. fitted
    connect l.N.E to point switch on power tripped rcd at board
    so I check wiring was correct simple enough. brown live blue neutral, Y/G earth.
    finally got cooker to only partially work (faulty spark generator on cooker wont switch off. new cooker)
    costumer only moved into property day before.
    now found after testing for let by and soundness glowworn hxi 30 boiler display would not come on .customer say's it worked the day before and the morning before fitting dual fuel indesit cooker.
    rang gloworm Technical, rubbish! could not get through, all info they claim is now online.(please note I did not touch boiler before the the above event was not necessary.
    what should I look/ test? example :-pump, low voltage side components, suggestion . note I am gas safe regs.
    always rated vaillant / glowworm boilers but their tech support total RUBBISH. now I will not quote for their boilers again unless the customer request it. I get through to Worcester far better than vaillant or glow worm
    Forum Thug
    croppie's Avatar
    23,822
    Croppie
    (By the way, I'm commercial!)
  1. Glow worm 30CXI F1 fault code
    By Kewat66 in forum Gas Safe Register Forum - Public Forum
    Last Post: 06-12-2014, 05:58 PM
  2. Shower fuse blown on main fuse board??
    By macka09 in forum Bathrooms, Showers and Wetrooms
    Last Post: 06-09-2014, 10:44 PM
  3. F4 fault code on Glow worm 30hxsi
    By Sanke in forum Central Heating Forum
    Last Post: 09-08-2013, 10:58 PM
