Plumbing & Plumbers Forum - Possible problem with the Central Heating Pump
Discuss Possible problem with the Central Heating Pump at UK Plumbers Forums; Hi, I have recently changed two radiators in my house. Due to a leak I had to drain the system and then refill. Upon restarting the boiler I have now ...
    Jan 2017
    Default Possible problem with the Central Heating Pump
    I have recently changed two radiators in my house. Due to a leak I had to drain the system and then refill. Upon restarting the boiler I have now a ticking/grinding noise which is coming from the pump, and no heating or hot water. The boiler is firing up, the programmer appears to be in order and the motorized valves are moving as expected. I am by far no means an expert at this but have done several plumbing jobs around my house but this has me completely stumped. How do I know if it is the pump or not and could it end up being the tank? Any ideas are greatly appreciated as the winter weather is hitting my area hard at the moment.
    Thanks.
    Super Moderator
    steveb's Avatar
    Nov 2007
    hythe hampshire
    12,854
    Default Re: Possible problem with the Central Heating Pump
    could well be air in the pump. turn everything off then with a screwdriver large enough carefully unscrew the big screw on the front of the pump with a towel held under it to catch any water that comes out. no need to unscrew it completely just enough to let any air out. you may need to do this a few times to rid of all air.
    Jan 2017
    Hi there,
    I have try this and as expected gunk did come out but once cleaning it and letting the air I put it all back together and still it is making a loud grinding sound when it is turned on. Any other ideas? I have a video to show if I can somehow get it uploaded to here. Thanks for the help
  1. Central Heating pump pump problem.
    By j4ffa in forum Central Heating Forum
    Last Post: 14-02-2015, 11:06 AM
  2. Central heating problem with boiler and a pump. PLEASE HELP
    By KrayonZ in forum Central Heating Forum
    Last Post: 08-05-2011, 09:36 AM
  3. Central heating pump amd 3 way motorised valve problem
    By Marmite in forum Central Heating Forum
    Last Post: 18-04-2011, 09:31 AM
  4. Central heating/hot water pump problem.
    By BigAl in forum Central Heating Forum
    Last Post: 25-09-2010, 12:41 PM
