Results 1 to 11 of 11
Plumbing & Plumbers Forum - New Boiler install
Like Tree13Likes
  • 3 Post By chris watkins
  • 1 Post By chris watkins
  • 2 Post By Masood
  • 4 Post By Abrwstr
New Boiler install
Discuss New Boiler install at UK Plumbers Forums; Hi We have just been allocated a sheltered bungalow by our housing association, it has a newly installed gas service and also a new boiler an ECO Combi Compact RF ...
    Sep 2016
    Default New Boiler install
    Hi We have just been allocated a sheltered bungalow by our housing association, it has a newly installed gas service and also a new boiler an ECO Combi Compact RF not sure if it is a 24, 30, or 36.
    The boiler is plugged into a standard kitchen wall socket there is no room thermostat or timer control clock.
    It has been intimated by the HA and their heating engineer contractors that the heating is controlled by the thermostatic valves on the radiators and that as we are in sheltered accomodation we would usually leave the heat on constantly, a timer control clock is only required if we were working in order to turn the heating on and off as and when we are in. A room thermostat is not required as we have thermostic valves on every radiator
    Currently in our home from which we are moving, we have set our controller to turn on at 07.30 in the morning and switch off at approx 22.30 in the evening and the temperature is controlled by a room thermostat in the living room.
    The housing association is guided by their Heating contractor.
    Are they right in what they are saying or are they assuming that because I am 71 years old I am a bit thick and will swallow whatever they say, Please any advice would be most welcome.
    Many thanks
    Tony
    rpm
    rpm is offline
    Member rpm's Avatar
    Wherever I lay my hat
    7,812
    Default Re: New Boiler install
    Quote Originally Posted by Abrwstr View Post
    Many thanks
    Tony
    Welcome to the forum Tony and we don`t care if you are 71 or 17, it is all straight answers to straight questions here.
  3. The Following 2 Users Say Thank You to rpm For This Useful Post:
    Somewhere in the South West
    109
    Hello Tony
    A Combination boiler should have a programmable room thermostat used in conjunction with thermostatic radiator valves (TRV's) as a mimimum. Just installing TRV's is not good enough in this day and age as it will not turn the pump off in the boiler and this will continually circulate which will cost you money. The programmable room thermostat will allow you to control the temperature at what level you want at times of the day to suit you. In the room that you have the programmable room thermostat you should not have a TRV on the radiator, it should be standard lockshield valves.
  5. The Following User Says Thank You to johnf For This Useful Post:
  6. #4
    Jun 2012
    London/Kent
    3,950
    Hi Tony
    Is this a new (ish) heating system ?
    As you guessed they are take you for a mug Building Regulation (Part L1a or b) state that there must be both time and temperature control over both the heating & if you have a hot water cylinder then that as well.
    Fitting TRV does not constitute control, as a minimum a room thermostat must be provide (normally in the hall) plus TRV in all rooms but that with the stat.
    joni os, Masood and julesverne like this.
  7. The Following User Says Thank You to chris watkins For This Useful Post:
  8. #5
    Jun 2012
    London/Kent
    3,950
    Quote Originally Posted by johnf View Post
    Hello Tony
    Tony writes a mean email so I have no reason to think that he couldn't program or use a programable room thermostat on the other hand his 20 year old wife may not be able to work it, so maybe have a time clock and room stat fitted or at least check that all will be able to use the controls first.
    There is no point installing complicated controls that customers can't / don't use, how many times do you see a heating system controls sole on the room stat.
    SteveWannadoGas likes this.
  9. The Following User Says Thank You to chris watkins For This Useful Post:
  10. #6
    Jun 2012
    London/Kent
    3,950
    Building Regs Part L is a legal requirement and this minimum level of control has been in place for something like ten years.
    Equally plugging a gas boiler into a socket has also not been allowed for a good number of years. They are required not least by the manufacturer to have their power supplies from a switched fused connection unit fitted with a 3amp fuse.
    If it is a new installation it (could) should not have been signed off to Building Control without these being completed, write to your housing association asking them to correct this so you can control your heating system economically.
  11. The Following User Says Thank You to chris watkins For This Useful Post:
  12. #7
    Masood's Avatar
    East London / Essex border
    4,763
    Hi Tony,
    Just to be clear, is this an Intergas Eco RF combi? As in the picture below:
    New Boiler install-intergas-combi-compact-eco-rf-condensing
    If so, it's really odd that you don't have a programmable room stat - these are designed to pair natively with the Honeywell CMT927 without need for a receiver!
    Why would anyone buy a boiler with that feature, the not supply the accompanying thermostat? It can't even be a cost decision, as the Eco RFs cost more than the other Intergas boilers which don't have the RF module!
    chris watkins and johnf like this.
    Find us at:
  13. The Following User Says Thank You to Masood For This Useful Post:
  14. #8
    Sep 2016
    Hi everyone,
    I got in touch with the the installers yesterday, their details were on the landlords gas safety check certificate (tennants copy) cuttin out the middle man (my landlord ) and quoting some of the info that I had got from your posts regarding Building regulations
    This afternoon a time clock and wireles thermostat were fitted, albeit rather reluctantly, but they were fitted, the electrician said that his company had not supplied a time clock, but when I said ok we will see you again shortly, when you come back with one, he suddenly found one in his van and fitted it.
    Now we have a fully functioning heating system.
    May I offer my heartfelt appreciation to all who took the time and trouble to offer their advice and support.
    Thank you all.
    Tony
  15. The Following User Says Thank You to Abrwstr For This Useful Post:
    rpm
  16. #9
    109
    Good one Tony. Glad to hear you got it sorted. I think they knew they were in the wrong.
  17. #10
    julesverne's Avatar
    bradford
    4,113
    great news Tony. great to hear you got it sorted in the end.
    Www.plumber-bradford.co.uk
    Hello to Jason Isaacs
  18. #11
    Jun 2012
    London/Kent
    3,950
    As above, take care Tony.
    I love these kind of threads, this is what a forum should be about.
    johnf, joni os and rpm like this.
  1. oil boiler install
    By chelsea in forum Oil and Solid Fuel Forum
    Last Post: 16-06-2016, 08:28 PM
  2. Need someone to install a new boiler
    By Lukefenner in forum I'm looking for a Plumber or Gas Engineer
    Last Post: 27-12-2013, 11:36 PM
  3. Boiler Install
    By southcoastboile in forum General Off-Topic Chat
    Last Post: 02-11-2012, 12:34 AM
  4. What boiler to install
    By Gas Jim in forum Gas Safe Register Forum - Public Forum
    Last Post: 24-10-2011, 03:45 PM
