Results 1 to 12 of 21
Plumbing & Plumbers Forum - External condensate pipe refused permission - help!
Like Tree7Likes
Discuss External condensate pipe refused permission - help! at UK Plumbers Forums; Hi there, The 21 year old boiler (Worcester Bosch 350) has failed in my first floor, small one bedroom flat which has concrete floors throughout. My existing boiler is in ...
    Jan 2017
    23
    Default External condensate pipe refused permission - help!
    Hi there,
    The 21 year old boiler (Worcester Bosch 350) has failed in my first floor, small one bedroom flat which has concrete floors throughout. My existing boiler is in a cupboard at the back of my lounge next to an outside wall. The flow and return pipes come out here too (I think they run under the concrete floor).
    I have been told that I need to install a new Condensing Combi boiler and the installer has recommended that I have a 1 and a quarter inch white (to blend in with the colour of the building) condensate pipe installed vertically to run out into a drainage channel at ground level.
    The owner of the flat below is a Director of the Management Committee together with one other Director.
    They have refused me permission to have the condensate pipe fitted externally.
    This is their reply:
    "The proposed pipe is far too obtrusive given the size and position and we can’t approve it.
    Any internal installation must be completely inaudible from outside the flat."
    Is this reasonable? Is it even possible for me the have a 'completely inaudible from outside the flat' pump installed? Won't there be occasional noise from the pump audible in the flat below - that is, in the Director's own flat??
    Any advice appreciated. Thanks!
    rpm
    rpm is offline
    Member rpm's Avatar
    Wherever I lay my hat
    7,835
    Default Re: External condensate pipe refused permission - help!
    Welcome to the forum munchkin.
    Jan 2017
    23
    Thanks, I appreciate it. A Worcester Bosch installer is going to fit the new boiler for me, and has assured me that noise shouldn't be an issue. (He doesn't know my downstairs neighbour though - lol!)
    Wish me luck.
    Any issues with these pumps, then please let me know. Thanks.
    Mar 2013
    1,336
    Their refusal to have 32mm pipe down external wall is justifiable.However, stating any internal installation must be COMPLETELY inaudible outside flat is not. The judgement in this case is what a reasonable person would deem acceptable. If your neighbour,Director,has particularly acute hearing and complains, suggest he takes up the matter with Environmental Health and be guided by their advise. The rights of all parties need to be balanced, including your right to heat home with a mandatory condensing boiler.
    munchkin19 likes this.
    Jan 2017
    23
    Thanks, Joni. You have phrased your answer brilliantly!!! I think I might just email most of what you've written directly through to the management company to cover myself in case of any complaints further down the line.
    That's great advice, and hugely appreciated!
    Mar 2013
    1,336
    Keep it as a response to any complaint after boiler installed. Just acknowledge their letter and state the boiler will be installed in accordance with manufactures instructions. If they object to that it further demonstrates unreasonable attitude and strengthens your case. Keep us updated.
    1,996
    How many flats in the block?
    Has anyone else got a condensate pipe down the wall, including the flat below?
    Has anyone else got a condensing boiler emitting "Obtrusive" condensation?
    This is going to be an issue for most of the flats I would guess.
    Where is the bathroom / kitchen / waste pipe soil stack in relation to the boiler?
    Riley's Avatar
    Sarf Coast
    6,381
    Yeah some piccies would be useful. Does the condense pipe 100% have to run externally
    Jan 2017
    23
    Don't know the answers to the first part (I rent the flat out but think I need to go over and have a closer look). My flat is one of two x one bedroom flats in the development. The other flats have either got balconies (with drains) or gardens.
    The bathroom/kitchen/waste pipe soil stacks are at the opposite end of the flat. So the boiler is on the window wall at the back of my lounge. The kitchen is at the front of the lounge, and the bathroom is to the left of the kitchen down a small (tiny) hallway.
    Doesn't leave me many options.
    Quote Originally Posted by snowhead View Post
    Jan 2017
    23
    External condensate pipe refused permission - help!-lounge.jpgThanks, Riley. Here's a picture of my first floor one bed flat showing the existing flue. My boiler is behind there in a cupboard at the back corner of my lounge. The first two windows are bedroom. Bathroom is at through a wall from the bedroom. The kitchen is at the front of my lounge and there is a tiny hallway separating my lounge from the bathroom. (So hard to describe.)
    There's a big bush type thing where the pipe would be going so most would be obscured. Anyway, even though the Worcester Bosch guy agreed that the external pipe would be the best solution, he said he could run a condensate pipe along the skirting boards in the bedroom and this will come out in the bathroom somehow. (Haven't quite got my head around it.)
    Attached Thumbnails Attached Thumbnails External condensate pipe refused permission - help!-img_4399.jpg   External condensate pipe refused permission - help!-back-flat.jpg   External condensate pipe refused permission - help!-img_4233.jpg
    SimonG's Avatar
    16,035
    Standard efficiency boiler.
    Somewhere in the South West
    109
    Who still makes a standard efficiency domestic gas boiler?
  1. Replies: 30
    Last Post: 04-01-2016, 06:53 PM
  2. External condensate
    By Mgrant in forum Plumbing Forum
    Last Post: 04-12-2015, 09:19 AM
  3. external condensate run
    By Killy Bing in forum Plumbing Forum
    Last Post: 20-11-2013, 09:58 PM
  4. External Condensate - Options
    By jjpearce05 in forum Central Heating Forum
    Last Post: 27-04-2011, 01:57 AM
  5. External condensate pipe
    By Gromit in forum Central Heating Forum
    Last Post: 17-01-2011, 02:00 AM
