Plumbing & Plumbers Forum - Worcester heatslave 15/19 not firing up
  • 1 Post By Best
Discuss Worcester heatslave 15/19 not firing up at UK Plumbers Forums; Hi guys, this is my first post so please let me know if I'm not in the right place for this posting. My problem 1. I came back from a ...
    Dec 2016
    Default Worcester heatslave 15/19 not firing up
    My problem
    1. I came back from a weekend away to find my boiler with no pressure and a circulating pump making a strange noise, no lockout was showing.
    2. I changed out the pump, found why the system had lost pressure( blocked expansion vessel hose caused the PRV to activate. no inhibitor from the looks of the gunk coming out when fully drained.)
    3. Repressurised system called for hot water and heat, circulating pump runs, no lockout
    4. Boiler didn't fire so I pressed the manual override button on the underside of the control panel.
    5. Blue flash and a blown fuse for my trouble!
    Where do I go next, is it the pcb thats knackered or is it one of the thermostats or something else.
    its very cold up here so any help to get us up and running again would be hugely appreciated.
    N.Ireland, United Kingdom
    6,905
    Default Re: Worcester heatslave 15/19 not firing up
    You really need to get a professional in now. Someone who is oil heating experienced or an electrician should hopefully test it all before ever putting power back to it.
    Suggest you put your general area and mention boiler type on looking for a plumber section of forum.
    AlexGas likes this.
  3. The Following User Says Thank You to Best For This Useful Post:
    Dec 2016
    Thanks for the advice, I think you're probably right, I was just hoping there may have been some fault finding solutions that could have narrowed it down a bit. I'm no sparky so best to admit defeat! �� If anyone knows of any simple checks please post!
  1. Worcester Heatslave 15/19 combi not firing
    By HHP Ed in forum Central Heating Forum
    Last Post: 1 Week Ago, 12:47 AM
  2. Heatslave 20/25 not firing
    By markadams in forum Oil and Solid Fuel Forum
    Last Post: 22-02-2016, 08:55 AM
  3. heatslave not firing up
    By CXR100 in forum Oil and Solid Fuel Forum
    Last Post: 17-03-2015, 12:23 AM
  4. worcester heatslave 20 / 25
    By P J F PLUMBING in forum Oil and Solid Fuel Forum
    Last Post: 25-04-2013, 09:18 PM
  5. Worcester Heatslave 26 32
    By julianhh in forum Central Heating Forum
    Last Post: 20-01-2010, 10:10 AM
