Results 1 to 11 of 11
Plumbing & Plumbers Forum - Combi on a 1 pipe system
Like Tree2Likes
  • 1 Post By ShaunCorbs
  • 1 Post By johnf
Discuss Combi on a 1 pipe system at UK Plumbers Forums; As above will it work? Doing a combi conversion and lifted some boards under radiator to alter some pipework and discovered the heating circuit is a one pipe system! I ...
    Aug 2010
    Bournemouth
    180
    Default Combi on a 1 pipe system
    I have only ever removed this type of system never connected onto it.
    I know the it won't be as efficient and I am going to recommend a re pipe. However will it work properly should they choose to ignore my advice?
    many thanks
    9,632
    Default Re: Combi on a 1 pipe system
    I will work but some manufacturers won't warrenty the boiler, also as you have said not very efficient
    Aug 2010
    Bournemouth
    180
    Cheers Shaun its a Worcester so will give them a ring and find out
    9,632
    Quote Originally Posted by KingDoey View Post
    Worcester are fine with it the only other one I know is villant
    Whyme likes this.
  5. The Following User Says Thank You to ShaunCorbs For This Useful Post:
    Aug 2010
    Bournemouth
    180
    Goody gumdrops
    Dec 2013
    The center of the universe
    4,158
    Thousands of one -pipe systems out there , if you hadnt lifted the boards you wouldnt have known
    Chalked's Avatar
    3,810
    Yet it will work, but my advice would be, go round and check all rads work before you start.
    I've been caught out before, by the customer that says " that used to work before you changed the boiler"! Only to take a board up to find it's been taken 20feet from the one pipe loop.
    As long as no one has adapted the system, all should be fine. Obviously, power flush before new install.
    Aug 2010
    Bournemouth
    180
    Cheers for the advice. Yeah system was powerflushed. Halfway through the job now so no going back. Customer is pretty sound though so shouldnt be any issues like that. Like i say we defo recommend it gets repiped
    Somewhere in the South West
    109
    Just make sure that the return temperature isn't too low. Some manufacturers say that the return to the boiler must be above 40 degrees to prevent the heat exchanger rotting out. If this is the case fit a bypass/three port mixing valve between the flow and return.
    You can't really powerflush a one pipe system very well as it wont go through the radiators without some persuasion. As said above it needs to be repiped.
    Reg Man likes this.
    Jan 2017
    Did the system work fine?
    Aug 2010
    Bournemouth
    180
    Flew round. Worked like a dream
  1. Gravity Fed System - upgrade to Combi/ High Pressure System
    By Homealone in forum I'm looking for a Plumber or Gas Engineer
    Last Post: 20-03-2016, 12:12 PM
  2. Replies: 10
    Last Post: 12-10-2013, 04:54 PM
  3. combi boiler on single pipe system
    By Wolfdreamer in forum Central Heating Forum
    Last Post: 09-10-2009, 08:52 PM
  4. combi on 1 pipe system
    By buster gonads in forum Central Heating Forum
    Last Post: 11-08-2009, 05:27 PM
  5. Could I have a combi to single pipe system ???
    By John Cotton in forum Central Heating Forum
    Last Post: 13-03-2009, 06:52 AM
