Old 24-11-2007   #1 (permalink)
Matty A
View Matty A's Photo Album
Default Diverter valve
Just a quicky
The other day my inlaws had no hot water so they called someone in who told them it was the diverter valve that needed replacing.They got a quote for £190 inc new valve they said it was gonna take 2 hours at £60 an hour and the part was £70 so i went to the plumbers merchants where i get my gear from and got a valve for £35 and i have changed it myself.
Now the problem i have is i drained the system and changed the valves over,i put the new valve in the exact way the old one came out ie Port A to Port A and Port B to Port B and i wired it in the same as the wires on both valves were both the same.
I have filled the system back up and bled the rads but the pump from the boiler is constantly running is there owt i can do?
Cheers
Mat
Old 28-11-2007   #2 (permalink)
John t
View John t's Photo Album
Default Re: Diverter valve
Sorry no one seems to have an answer for you matty, did you get it sorted?
John t is offline   Reply With Quote
Old 01-12-2007   #3 (permalink)
Matty A
kinda
Maybe you can help me
When i boost the hot water sys when the heating is on the radiators go off downstairs this is when the pump is on setting 1 if i turn pump upto number 2 it is all working ok BUT the pump is so noisey i was wondering if there could be air in the cylinder is this possible if so how do i bleed it????
HELP
cheers
Mat
Old 01-12-2007   #4 (permalink)
John t
Not sure if it's air but if you have a hot water cylinder there will be a bleed valve next to it on a vertical pipe coming from the heating pipe work!
Old 03-12-2007   #5 (permalink)
Matty A
yes there is i thought that was just to drain down to a certain level for maintenance works think ill try that cheers
1/4 turn bath valve jules1234 Valves & Taps 1 4 Weeks Ago 10:21 PM
non return valve on incoming main? Readingplumber Water Regulations 4 4 Weeks Ago 06:19 PM
Unknown valve the watchman Plumbing Forum 6 11-10-2008 08:05 PM
Whats this valve for? plotnine Central Heating Forum 2 14-09-2008 06:05 PM
Thermostatic bar valve shower evertech Showers and Wetrooms 2 31-07-2008 04:15 PM
