Plumbing & Plumbers Forum - Isolation valves on central heating
Discuss Isolation valves on central heating in the Central Heating Forum at Plumbers Forums; I am currently building an extension. As we are just finishing one room at a time I had an idea of using isolation valves below the floorboards for each drop ...-
24-02-2010 #1New to Plumbing Forum
- Jan 2010
I am currently building an extension. As we are just finishing one room at a time I had an idea of using isolation valves below the floorboards for each drop to the proposed radiators.
The system is off a combi boiler. 22mm ring around the house with 15mm drops down or up to each rad. Would this be a good idea?
I know this may restrict flow (as on standard isolation valves the opening looks about 10m) but on the rad TRV’s and shut off valves, the opening too looks only to be 10mm csa.
Any advice would be appreciated.
24-02-2010 #2uɐɯ sɐƃ moderator
- Jan 2010
- maesteg,south wales
- 13,564
- 836
- Thanked 1,284 Times in 1,225 Posts
Re: Isolation valves on central heating
no not a good idea isos or ballofixs can leak trough the center better to put the drops in their desired position and use cap ends
GASMAN
24-02-2010 #3Plumbers Arms member
- May 2009
- 7,302
- 218
- Thanked 683 Times in 604 Posts
As said would not put valves in
You have a combi system so quick to drian down,put good drain point on and by the time you are sorted to connect rad pipework runs, as you go along, required pipework will be drained and ready to connect up,and another 10/15 mins to refill,you are going to have to fill the new sections anyway
central heating and hot water not working again..
By mad_cereal_love in forum Central Heating ForumReplies: 3Last Post: 02-02-2010, 08:47 PM -
Central heating in need of some professional TLC
By mikemycrfot in forum Central Heating ForumReplies: 4Last Post: 31-12-2009, 02:54 PM -
Help! Builder has messed up central heating
By tropical lounge in forum Central Heating ForumReplies: 23Last Post: 19-12-2009, 05:20 PM -
service valves in central heating system
By AJ16 in forum Central Heating ForumReplies: 16Last Post: 22-11-2009, 12:14 AM
still learning
1 Minute Ago in Central Heating Forum
