Quote:
Originally Posted by fuzzy
dont fill to 1.8 bar thats too much. it may be over pressurised when hot, then it blws of at 3bar. better leave the cold pressure at 1bar, should rise to around 1.5 on heating.
if at these pressures it still drops check your expansion valve and pressure vessel
I didn't fill it to 1.8 bar the central heating engineer I have the service contract with filled it to that and said it was OK as the pressure relief valve would vent any excess water.
I t's been 2 weeks since he was here and the cold pressure is maintaining at 1.2 bar and the hot pressure is now at 1.8 bar, but the hot water temp has been lowered to 50 degrees which I assume would have an effect on the hot pressure (lowering it due to lower heat expansion). It seems to be stable for now but I have had this problem for a while now and I fully expect it to drop of slower as the pressure gets lower. If anything changes I will post a reply.
