Old 28-06-2008   #1 (permalink)
ANDYSI
View ANDYSI's Photo Album
Default Biasi 24 Pressure Dropping
I Have A Problem With A Biasi 24s 90e Combi Boiler Where The FILLING Pressure HAS DROPPED FROM ABOUT 1.8 BAR TO 1.2 BAR IN 2 WEEKS, BUT THE HEATED PRESSURE HAS REMAINED CONSTANT. IS IT MORE LIKELY TO BE A LEAK OR A FAULT WITH THE GAUGE AS I CANNOT UNDERSTAND WHY THE FILLING PRESSURE IS DROPPING BUT THE HEATED PRESSURE HASN'DROPPED AT ALL.
ANDYSI is offline   Reply With Quote
Old 29-06-2008   #2 (permalink)
ajs heating
Posts: n/a
Default Re: Biasi 24 Pressure Dropping
whats filling pressure and heated pressure ?
Old 30-06-2008   #3 (permalink)
ANDYSI
filling pressure started at 1.8 bar now 1.2 bar. Heated presure 2.2 bar constantlyand hasn't changed even though filling pressure has dropped.
Old 01-07-2008   #4 (permalink)
spacethegas
View spacethegas's Photo Album
probably nothing to worry about. especially if it has been drained recently. the air in the system is just venting through aav. just top it up again to 1.5 bar. if it drops to 0.5 bar within a month you may have a problem.
i don't do dumpers.
spacethegas is offline   Reply With Quote
Old 03-07-2008   #5 (permalink)
fuzzy
View fuzzy's Photo Album
dont fill to 1.8 bar thats too much. it may be over pressurised when hot, then it blws of at 3bar. better leave the cold pressure at 1bar, should rise to around 1.5 on heating.
if at these pressures it still drops check your expansion valve and pressure vessel
Old 04-07-2008   #6 (permalink)
ANDYSI
I didn't fill it to 1.8 bar the central heating engineer I have the service contract with filled it to that and said it was OK as the pressure relief valve would vent any excess water.
I t's been 2 weeks since he was here and the cold pressure is maintaining at 1.2 bar and the hot pressure is now at 1.8 bar, but the hot water temp has been lowered to 50 degrees which I assume would have an effect on the hot pressure (lowering it due to lower heat expansion). It seems to be stable for now but I have had this problem for a while now and I fully expect it to drop of slower as the pressure gets lower. If anything changes I will post a reply.
Boiler gas feed pipe pressure... JMA Plumbing Forum 11 03-11-2008 12:02 AM
Gas Inlet Working Pressure in Vaillant 630 system boiler hughs Central Heating Forum 2 25-10-2008 07:24 PM
High pressure for couple seconds.. zxac Plumbing Forum 5 16-10-2008 05:20 PM
Hot water fine pressure on heating building up David Want Central Heating Forum 1 06-10-2008 09:16 PM
