Re: Pump Differential
Are you sure the pump is spinning and you are not just feeling a buzzing from it? If it isn't, then the condenser (capacitor) is likely shot and so replace it. I think they are 2.5 microfarrad but you would have to check.
If the pump is actually spinning, check the pipe circuit. Could a bypass valve be too far open?
If the pump is spinning but sluggishly, then the motor windings have deteriorated and I'm afraid it's a replacement.
To check for sure, take the pump off. rig it up to a header tank full of water and run it. If you can place your thumb over the end and stop the flow, it's the motor.
Reason: Automerged Doublepost
