Hi
I need to upgrade my old system boiler as the exixting one is under powered following recent extension works to my property.
The house has cavity wall insulation, 300mm loft insulation and plastic framed double glazing. The property is a compact 4 bedroom house with bathrooom and en suite. There is also a conservatory with large radiator. In total there are 13 radiators and when i add up all the outputs of each radiator and allowing 2kw for the unvented cylinder it comes to 14KW.
I want a Worcester Bosch wall mounted system boiler but not sure which model would be best suited to the system requirements. I've had vastly varying recommendations on size and have been left a unsure which model to choose
I would be very greatful for your help on choosing the correct size?
p.s Our current boiler is rated at 8.8kw and has to run 24-7. It can just about manage to keep the house at about 19 degrees C and the water at 60 degrees C with a very very slow reheat time.
Thanks to all
