Old 23-06-2008   #1 (permalink)
Hoof Hearted
View Hoof Hearted's Photo Album
Default Boiler Size
I got a plumber to give me a quote for installing Central Heating. I have a large house, but I was surprised when he proposed a 140,000 BTU boiler. I've done the std calculation of measuring the room volumes and multiplying by 3,4 or 5. I only get 67,000 BTU. If I multiply all the volumes by 5 I still only get 76,000 BTUs required. I've tried a few of the on-line calculators. The worst case I found was one site that suggested a boiler 90,000 BTUs. What makes me more concerned is that the radiators he specified are only capable of giving out 86,000 BTUs.
Can anyone suggest why he might have specified such a large boiler? Are there any upsides, and what are the downsides I might see? The only thing I can think off is that i've got 18" solid stone walls. This will need a larger boiler than usual, but surely I should have radiators that can give out at least as much heat.
Ian
Hoof Hearted is offline   Reply With Quote
Old 23-06-2008   #2 (permalink)
spacethegas
View spacethegas's Photo Album
Default Re: Boiler Size
I need a little to go on.
how many bedrooms ?
on suites ?
how many bathrooms ?
solid walls ?
open plan ?
insulation/heat loss ?
what sort of boiler/system is proposed ?
for eg i live in a small end terrace 3 bed 1 bath. i wanted a high flow rate (13 l/min) combi.
Hence i installed a 130,000btu blr.
more than enough to run ch & will easily cope with a planned extension.
spacethegas is offline   Reply With Quote
Old 23-06-2008   #3 (permalink)
Hoof Hearted
It's a 3 floor 5 bedroom end terraced house. No extension possible. No Ensuites. 1 Bathroom + second toilet downstairs.
18" Solid stone Walls. No open plan. Loft insulated. Hardwood d/glazed windows. Total room volume including hall and landings 15200 cu ft.
He's proposed a Worcester Bosch 42 CDI
Ian
Old 23-06-2008   #4 (permalink)
spacethegas
To be honest without me actually coming round it sounds just the job.
17ltrs/min hot water.
Old 23-06-2008   #5 (permalink)
Hoof Hearted
But how about 140,000 BTU's being pumped into radiators that can only give out 86,000? Is this not wasteful?
I just measured the maximumum flow from my hot tap in the Kitchen. I got 9 Litres/min. The bath is almost never used in my house. So 9 Litres/min is plenty
Old 23-06-2008   #6 (permalink)
spacethegas
its not wastefull the boiler is range rated & will run as the system demands.
is this ltr/min from cold tap ?
sorry reread it.
measure cold tap.
Your hw flow rate should improve no end. ie Superb shower
Old 24-06-2008   #7 (permalink)
Hoof Hearted
The kitchen cold tap is giving about 25 Litres/min. It's near the incoming cold main. The cold bath tap is only giving 20 Litres/min
Old 24-06-2008   #8 (permalink)
CharterGAS
View CharterGAS's Photo Album
i Hope you can range rate the cdi!!!! or you are wasting energy!!
Old 24-06-2008   #9 (permalink)
Hoof Hearted
Interesting! I just took a closer look at the technical data for the boiler in question....
The Greenstar CDi Series at a glance - Worcester Homeowner area
Yes it's a 42KW boiler, but the full 42KW is only available to the hot water. The central heating gets from 9.4KW up to 30KW. This is sounding more like it. The 30KW is only 5KW above the radiator capacity.
I couldn't help but notice though, that the 30, 37 and 42CDI models all give 30KW to the central heating. So you pay your extra money just for the better hot water flow.
Old 24-06-2008   #10 (permalink)
fuzzy
View fuzzy's Photo Album
most modern boilers if not all are reange rated
Separate pump in addition to the one included in the condensing boiler? hughs Central Heating Forum 7 2 Weeks Ago 06:05 PM
Boiler gas feed pipe pressure... JMA Plumbing Forum 11 4 Weeks Ago 12:02 AM
problem with commercial boiler. griffdsp Plumbing Forum 0 4 Weeks Ago 09:53 PM
Advice require - Electric Water Heater / Old Gas Boiler salbal77 Plumbing Forum 0 12-10-2008 07:18 PM
disconect solid fuel back boiler spencer Plumbing Forum 1 22-09-2008 03:19 PM
