Results 1 to 2 of 2
Plumbing & Plumbers Forum - Problem with British "Scottish" Gas EMT2 heating controller.
Discuss Problem with British "Scottish" Gas EMT2 heating controller. at UK Plumbers Forums; Hi folks, hopefully you can help me with this... I have a gas fired heating system at home, controlled by a 'Scottish Gas' branded 'EMT2' controller/timer. As things stand, the ...
    Jan 2015
    Default Problem with British "Scottish" Gas EMT2 heating controller.
    I have a gas fired heating system at home, controlled by a 'Scottish Gas' branded 'EMT2' controller/timer. As things stand, the heating will not fire up, I can get hot water by manually switching on the boiler via the mains switch on the wall. When I attempt to turn the heating on, the red power led light on the EMT2 lights up fully for a few seconds (or less) then dims down to a kind of half power glow or less. The heating does not come on, but the unit seems to still be ticking over, the timer dial rotates as normal.
    Any ideas ?
    Cheers
    Al
    bigads28's Avatar
    Aug 2014
    Moray
    423
    Default Re: Problem with British "Scottish" Gas EMT2 heating controller.
    Could be a whole string of things Allen, usually not the clock. If both won't work off the clock then chances are it's the boiler.
    Time to call the gas safe bloke I'm afraid.
  1. Central Heating Controller Mystery
    By simon.clark7 in forum Plumbing Forum
    Last Post: 08-05-2013, 08:50 AM
  2. New heating controller needed... but which one.
    By besidog in forum Central Heating Forum
    Last Post: 05-01-2013, 11:25 AM
  3. Drayton LP522 controller problem
    By AndyP1968 in forum Plumbing Forum
    Last Post: 07-11-2012, 02:50 AM
  4. New Heating/hot water controller
    By kiltedjock in forum Plumbing Forum
    Last Post: 23-10-2012, 11:24 PM
  5. Programmer/Controller problem
    By snowglowjoe in forum Central Heating Forum
    Last Post: 03-11-2011, 08:59 PM
scottish gas emt2
british gas emt2
british gas emt2 timer replacement
what unit to replace scottish gas emt2
emt2 scottish gas
