Old 14-06-2008   #1 (permalink)
berthollywood
View berthollywood's Photo Album
Default hot water cutting out! performa 28
my potterton performa 28 keeps cutting out whilst the hot water tap is on,
the led indicator builds up to 80 then cuts out,there is no fault light being lit on the fault panel,ive recently changed the hot water temp sensor and the problem is still there......
after it cuts out it restarts after about 5 sec,ive tryed running the CH and it doesnt cut out...
ive had a plumber out and he checked gas valve which he said was ok and he indicated that it could be a fault on the pcb which he quoted me £150 to change...
The problem has gradually got worse over the last 12 months to the point that we can no longer run a hot bath..
my water pressure is really good so i dont think its anything to do with that
does anyone have any ideas? thanks for any advice given
berthollywood is offline   Reply With Quote
Old 14-06-2008   #2 (permalink)
CharterGAS
View CharterGAS's Photo Album
Default Re: hot water cutting out! performa 28
its the water section!!!! Fire the plumber he doesn't know what hes doing !!
the diaphragm in the water section is weak and needs replacing. yo can be th e diaphram its self or the valve which takes about 30 mins to change!
Its the water section!!!! also known as the pressure differential valve !!
Fire your plumbing he doesn't know what hes doing hes only guessing!!!
You can but the diaphragm buy its self or the
valve assembly which is easy to replace
Old 14-06-2008   #3 (permalink)
berthollywood
hi,would you recomend to change the whole valve or just the diaphram,thanks
is this the part you mean,thanks
Diverter Valve Baxi DHW Flow Valve 248063 on eBay, also, Plumbing, DIY Materials, Home Garden (end time 15-Jun-08 12:13:28 BST)
Old 14-06-2008   #4 (permalink)
CharterGAS
yes thats the part but double check with potterton on your part numbers!!!
its easier to change the valve than the diaphragm as in less time!!!!
i would get another local plumber in to give you a definite diagnoses as i can only give limited advice as im not in site!!
Old 14-06-2008   #5 (permalink)
berthollywood
ok thanks for your help,ive been studying my installers instructions and parts list and have got the part no for a pressure differential valve diaphragm but have noticed that there is a 3 way valve diaphragm aswell,would it be either of the diaphragms that would cause the same problem or just the pressure differential valve diaphragm?
is about £60 a decent price for this part?thanks
Old 14-06-2008   #6 (permalink)
CharterGAS
i suspect just the pressure differential diaphragm, but like i say seek local expert advice to confirm
Old 16-06-2008   #7 (permalink)
berthollywood
i checked the diaphragm in the dhw differential valve and also the one in the 3 way valve and both are ok......
when putting the boiler back together i swapped the CH temp sensor with the DHW temp sensor,the hot water seems to be working better....well it hasnt cut out yet,but will se how it goes over the next few days
I tried to start the CH to see if that was ok,but wouldnt start,so maybe the CH temp sensor was affecting the hot water...i dont know....i will se how it goes over the next few days and post results
Old 17-06-2008   #8 (permalink)
CharterGAS
double check the ohms reading on the sensor at a high temp the reading should be low
at cold it should be a high reading
Old 17-06-2008   #9 (permalink)
berthollywood
I take it this is something i am going to have to call a plumber out to do?
after swapping sensors hot water is still cutting out but not as often and the water is not going as cold before it heats up again
Old 17-06-2008   #10 (permalink)
CharterGAS
yeah get some one out
sound like it the hot water ntc and still possibly the differential valve. when you say you checked it, how did the rubber feel? still tight or a bit loose??? it maybe that the rubber has lost a bit of elasticity and causing the problem
External Links: Download movies : Mortgage : Loans : New York Hotel : Debt Management
Electrical Help
Tiling News
Tiling NVQ
Tilers Tools
Tiling Network
Electricians Forum
Conservatories UK
Tile Forum
Search Engine Optimisation
Tile Pages
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21
