Re: hot water cutting out! performa 28
rubber felt a bit loose but was not damaged in anyway,the differential valve is still operating the pressure microswitch in the normal way,and is still operating microswitch up-until hot water cuts out,if the diaphram was damaged would the micro-swith not be operated?
CH working normal,the CH return stop-tap was closed preventing the heating from running,must of been closed by plumber last week.....
ive ran the CH for about 30 min to see if it was cutting out too but didnt,gas was modulating as it should,so still left with same problem of hot water cutting out
