Results 1 to 4 of 4
Plumbing & Plumbers Forum - New pipes causing water hammer - pls help
  • 1 Post By Subby
Discuss New pipes causing water hammer - pls help at UK Plumbers Forums; Hi Im a new member with a problem - Our upstairs water supply comes under the floor boards in a bedroom into a toilet then through a wall into the ...
    Sep 2014
    Default New pipes causing water hammer - pls help
    Hi Im a new member with a problem - Our upstairs water supply comes under the floor boards in a bedroom into a toilet then through a wall into the bathroom . we have replaced the section of 2metre piping in the bathroom. but every time we flush the toilet the pipes are making a hammering noise which seems to come from the 'old' piping under the floor boards in the bedroom. the old pipe is 22m but the new pipe is 15m - do I need to replace all piping. I hope not? Any advice
    Mar 2012
    Bolton
    2,097
    Default Re: New pipes causing water hammer - pls help
    First thing to try is to clip the pipe, not just the new section but all of the run. My thinking is that the old 22mm was much sturdier stuff than the new 15mm and this new section will have weaked the span of pipe.
    I doubt you can have too many clips, but you can have too few - so don't be shy with them
    The regs say 1.2m intervals for 15mm copper, I'd over cook that a little if I was trying to resolve a water hammer issue.
    Jan 2009
    Corsham, Wiltshire
    1,723
    Shock arrestor? Surely having restricted the flow going from 22 to 15 it has now speeded up the velocity (Bernoulli principle ) whereas prior you had the larger bore pipe.
    Sep 2012
    Cardiff
    429
    It is quite possible that your fill valve was fitted without the flow restrictor. Replace the WC fill valve with a fluidmaster or similar, this should stop any water hammer. Failing that you could fit a shock arrestor near the WC end of the pipe run.
    josh likes this.
  1. Replies: 8
    Last Post: 27-07-2013, 07:50 PM
  2. Combined F & E pipes causing 3 rads to not perform
    By buryboy in forum Central Heating Forum
    Last Post: 08-12-2012, 01:23 PM
  3. Replies: 22
    Last Post: 19-12-2011, 08:27 PM
  4. Cold weather causing noisy pipes
    By jase158 in forum Fittings & Pipes
    Last Post: 29-01-2011, 07:09 PM
  5. What is causing my pipe hammer...?
    By mykeyj in forum Plumbing Forum
    Last Post: 20-03-2010, 02:12 AM
new pioe plumbing
