Re: Balancing problems with Honeywell TRV's
you normally balance using the lock sheilds on the return, is this possible?
take of all trv heads so fully open and run heating, balance each rad with LS, then replace all heads. Should only turn off when satisfied.
I have had a problem with some trvS IN THE PAST, some have a limiting piece of plastic internally, just flick it out, some just too sensitive! had to back of the thread to allow to open!
hope some of tis helps, let me know how you go on dbharrion
