Old 05-06-2008   #1 (permalink)
RON
View RON's Photo Album
Default C/H header tank feed pipe pushing hot water into tank
Hi all
Not actually name Ron but i am using my late uncles name as i did my apprentiship with him back in the late sixties. I have not worked as a plumber for a number of years at least 30 years but still enjoy the odd job for family. The problem below is happening at work and is in a two storey building, boiler ground floor cylinder ground floor and header tank in the loft of a two storey building.
Hot water is Gravity fed, heating is pumped system.header tank is filling up via the feed pipe and the water is hot, and no water appears to be coming out of the expansion pipe. The rate of overflow is probably about a litre per 4 hours
Pump on middle setting. No other problems with system. Only appears to happen when the heating is on, but will check tomorrow to see if it happens when on hotwater only.
Any suggestions gladly appreciated
cheers
John alias Ron
RON is offline   Reply With Quote
Old 06-06-2008   #2 (permalink)
ajs heating
Posts: n/a
Default Re: C/H header tank feed pipe pushing hot water into tank
if it a gravity system and pumped heating you won't be able to get heating on its own only if wired as a c plan.
if not you will get either hw only or hw/heating.
is the heating f/e tank lower than the cws tank for the hot water ?
1, either a split coil in the cylinder.
2 blockage in the pipework useally around the fed/vent pipe area.
has it got an air seperator on the vent/feed pipe?
try turning the pump speed down to min.
need some more info.
Old 07-06-2008   #3 (permalink)
fuzzy
View fuzzy's Photo Album
but aj, if the boiler only on without pump then surely you can get HW only? you cannot get heating only , have i missed something or did you type it wrong?
Old 07-06-2008   #4 (permalink)
ajs heating
Posts: n/a
fuzzy where do you see the mistake ? i've read it and can't point it out
i 've put you can get hw on its own.
(programmer set to hw) (programmer set to hw/heating)
the only way you can get heating on it own is if wiring as a c plan with a zone valve.
just that explain it better? correct me if im wrong
Old 07-06-2008   #5 (permalink)
fuzzy
my fault aj, i read it the wrong way round!
your right
Old 07-06-2008   #6 (permalink)
ajs heating
Posts: n/a
had me confused then.
Old 07-06-2008   #7 (permalink)
RON
Hi and thanks for replying
You are correct it is h/w only and h/w +heating
The heating header tank and the cold water storage tanks are the same level (both sitting on joists)
Will try turning the pump down.
I will also check the overflow situation in the h/w only mode, as it seems worse when the heating is on.
I will post the outcome next week
thanks again
Old 07-06-2008   #8 (permalink)
ajs heating
Posts: n/a
yes but the water levels in the tanks willbe different, the cws storage should be higher than the f/e for the heating.
1, try turning the pump down to min. see what happens.
2, shut the gate valve to the hw cylinder from the cws tank in loft.
does it stop then ?
Old 10-06-2008   #9 (permalink)
RON
Hi AJ
The pump has now been turned down but as yet I have not run H/W and C/H together. The H/W only has been running and the C/H header tank is continuing to overflow. It appears to overflow more when the boiler kicks in (obvious really i know). I will run the heating in the morning and see what happens
Ron
Old 12-06-2008   #10 (permalink)
RON
Hi AJS
The coil has gone as you suggested. Thanks for all your help.
Ron
oil tank pipe george Fittings & Pipes 3 11-08-2008 04:33 PM
Header Tank Overflowing with Warm Water stewartacraig Plumbing Forum 12 05-07-2008 12:11 PM
Header Tank Overflow All Mod Cons Central Heating Forum 10 24-06-2008 12:09 AM
C/H header tank feed pipe pushing hot water into tank RON Central Heating Forum 0 05-06-2008 11:19 PM
Header Tank Overflow 2 All Mod Cons Central Heating Forum 9 27-04-2008 09:36 AM
External Links: Personal Loans : Loans : Personal Loans : Car Credit : Car Insurance
Electrical Help
Tiling News
Tiling NVQ
Tilers Tools
Tiling Network
Electricians Forum
Conservatories UK
Tile Forum
Search Engine Optimisation
Tile Pages
