Old 21-05-2008   #1 (permalink)
Nige
View Nige's Photo Album
Default Radiators not warming up!
I recently changed two wheelhead valves on two rads in a small flat. It has one rad at the bottom of the stairs, and four upstairs in the living area. It is heated by a back boiler, has a hot water cylinder, tanks in the loft space above etc. It took a while to drain the system down (the water was clean), and to bleed.
With all the wheelheads and lockshields fully open, only two of the upstairs rads are getting hot at the top, no warmth at all in the others and the pipes to the downstairs rad stone cold.
The room stat is turned up to max which must exceed actual room temp, the pump is on speed setting 3.
Any thoughts would be greatly appreciated, this is the first time I've worked with a back boiler, wonder if I'm missing something really obvious, or if its just a stubborn air lock!!
Nige is offline   Reply With Quote
Old 21-05-2008   #2 (permalink)
ajs heating
Posts: n/a
Default Re: Radiators not warming up!
shut all the rads and open the lowest one till it gets hot.
then try another rad till it gets hot etc.
sounds like a airlock in system.
if this fails could be sludged up and would need to know more about the system
Old 22-05-2008   #3 (permalink)
Pendle Plumber
View Pendle Plumber's Photo Album
I think it needs balancing as ajs heating said may be sludged up in which case powerflush may be needed.
Pendle Plumber is offline   Reply With Quote
Old 22-05-2008   #4 (permalink)
Nige
Thanks v much for that. Will give it a go.
Old 26-05-2008   #5 (permalink)
ViSaGe
View ViSaGe's Photo Album
could be the pump, try it on no.3 see if that helps.
ViSaGe is offline   Reply With Quote
Old 26-05-2008   #6 (permalink)
ajs heating
Posts: n/a
if you read the post again you will find it's on 3.
Old 26-05-2008   #7 (permalink)
ViSaGe
my speed Reading failing me again try reversing the pump to see it that helps.
Radiators Won't Fill Up HELP! Muushy Central Heating Forum 12 2 Weeks Ago 06:32 AM
Nearly cold radiators MattBCardiff Central Heating Forum 6 4 Weeks Ago 04:27 AM
cost of quote for replace of old radiators flozz Plumbing Forum 8 4 Weeks Ago 08:40 PM
Radiators need bleeding every couple of weeks tedson Central Heating Forum 2 22-10-2008 10:20 PM
Radiators need bleeding every couple of weeks tedson Central Heating Forum 0 14-10-2008 08:11 AM
