Page 1 of 3 123 LastLast
Results 1 to 12 of 29
Plumbing & Plumbers Forum - Honeywell wireless not binding!!!
Like Tree6Likes
Discuss Honeywell wireless not binding!!! at UK Plumbers Forums; Hi, at the best time of the year, I discover that my honeywell st9420c has lost its wireless connection with the room stat and now will not 'bind' with the ...
    Nov 2013
    Lightbulb Honeywell wireless not binding!!!
    Hi, at the best time of the year, I discover that my honeywell st9420c has lost its wireless connection with the room stat and now will not 'bind' with the unit. Following the instructions both units correctly go into the binding mode but it never compleates successfully! Anyone with know or similar experience please advise, Thanks
    mountainman's Avatar
    Jan 2012
    Essex
    4,747
    Default Re: Honeywell wireless not binding!!!
    I hate wireless controls.
    Have you put new batteries in the sender unit?
    Si hoc signum legere potes, operis boni in rebus Latinus alacribus et fructuosis potiri potes!
    Nov 2013
    Yes, new batteries, units are next to each other so its not a distance thing, I'm beginning to dislike too, but its only about 16months old!!!!
    Jan 2012
    Essex
    4,747
    A new unit is required methinks.
    Member Dan Masey's Avatar
    Bristol
    210
    yep i had this mate with mine, i contacted honeywell directly, they sent me an email of a step by step guide which they do not put in the user guide or manuals online.
    here it is.
    REBINDING RF PACK - ST9420C PROGRAMMER TO THE DT92E ROOM THERMOSTAT
    FROM THE ST9420C PROGRAMMER
    Ensure the slider is in RUN
    Press and hold +, - and Heating mode buttons for 8 seconds
    BIND MENU will show briefly, followed by first binding display
    Use + and to select the Radiator symbol, Press OK
    If display shows -- -- - - nothing bound
    If display shows bnd something already bound
    (If you want to cancel existing binding press OK for 8 seconds and the display will say RESET for a few seconds), then
    Press OK to put in binding mode, display will flash BINDING ready to receive, ---- will flash
    FROM THE DT92E – HANDHELD THERMOSTAT
    Hold DT92E approximately 1 metre from ST9420C
    Press and hold the power button for 2 seconds
    Hold the and for 3 seconds until Inst is displayed
    Press and the display shows Cont
    Pressing the 3 times and the display shows CLr
    (Press the power button until --- if you want to clear existing binding data)
    To put into binding mode press the display will show Cont
    Press power button to send binding message display will show Sync up to
    4 minutes
    If binding has been successful bnd will be shown on the ST9420C and display will show COMPLETE for a few seconds and bnd will stop flashing
    If the binding was unsuccessful the ST9420C will show ----flashing
    To exit binding mode put slider to RUN on the ST9420C.
    Jan 2012
    Essex
    4,747
    Jeez, I'd run a cable and fit a wired 'stat.
    happyflyer and plumber0808 like this.
    May 2013
    Manchester
    1,458
    Quote Originally Posted by mountainman View Post
    You mean in the time it takes to bind???
    Nov 2013
    Thanks Dan, these are the instructions I followed. It just never actually successfully binds. Just continues to flash as if both units are still looking for each other, ending up timing out after 10 mins or so. I have been over it so many times, they must be a fault but in the controller or the room stat, who knows?
    lame plumber's Avatar
    Nov 2012
    North Devon by the sea
    15,664
    change the frequency settings, could be a new computer wireless unit interfering,
    www.jcdheating.co.uk
    May 2013
    Manchester
    1,458
    Quote Originally Posted by lame plumber View Post
    Lame,
    How many different channel are there on these units.
    Nov 2013
    Lame, how do I change the frequency settings?
    May 2013
    Manchester
    1,458
    Yes Lame can't see it in the destructions
  1. Honeywell CM921 Wireless Thermostat Problems
    By Robbo2013 in forum Central Heating Forum
    Last Post: 14-10-2013, 09:41 PM
  2. vokera vision / honeywell cm927 wireless programmer
    By richardd in forum Gas Safe Register Forum - Public Forum
    Last Post: 27-05-2013, 12:52 PM
  3. replace old Honeywell T40 stat with Wireless DT92E
    By adriaan029 in forum Central Heating Forum
    Last Post: 05-11-2012, 09:26 AM
  4. Honeywell dt92e wireless help needed
    By plumbdoctor in forum Central Heating Forum
    Last Post: 25-07-2011, 08:41 PM
  5. Help from you experts on honeywell dt92a wireless stat
    By plumbdoctor in forum Gas Safe Register Forum - Public Forum
    Last Post: 25-07-2011, 02:58 PM
  6. Honeywell dt92e wireless please help
    Last Post: 25-07-2011, 01:50 PM
  7. honeywell wireless programmer & stat
    By ATN in forum Central Heating Forum
    Last Post: 22-04-2011, 09:45 PM
  8. honeywell wireless programmer and Vaillant boiler
    By yacine in forum Plumbing Forum
    Last Post: 11-01-2010, 09:10 PM
  9. hi
    By mcmoby69 in forum New Member Introductions
    Last Post: 22-08-2007, 12:08 AM
honeywell st9420c
honeywell dt92e problems
binding honeywell thermostat
honeywell cm921 troubleshooting
honeywell dt92e sync
