Re: Power flushing
oh i do like a laugh
as uug197h said you can do powerflushing if you can do the rest that gos with it.
understanding a central heating helps as 9/10 systems that powerflushing also need extra work as well, as in radiator valves changed, understanding where the blockages occur, how to powerflush a heat exchanger, use the right chemicals for the right job as many can distroy a combi boiler.
people use powerflushing as a way to print money in many cases a good chemical in the system for a while and then flushed will sort the problem.
you won't earn a living out of just powerflushing.
