Results 1 to 9 of 9
Plumbing & Plumbers Forum - Serviceplus s17r
Serviceplus s17r
Discuss Serviceplus s17r at UK Plumbers Forums; Good eve all Does anyone know the button sequence to reset the service timer on Horstmann Service Plus s17r I was breifly told on the phone but didnt quiet catch ...
    Sep 2013
    Default Serviceplus s17r
    Good eve all
    Does anyone know the button sequence to reset the service timer on Horstmann Service Plus s17r I was breifly told on the phone but didnt quiet catch it all I know you need a fob for the drayton version,but I do know there is a way of doing it on the S17r
    Many Thanks
    Steve
    Ultimate Gas
    Norfolk
    3,000
    Default Re: Serviceplus s17r
    Press the SET and SELECT buttons together to reset back to factory settings.
    Sep 2013
    Thanks for the reply this does not reset the service timer as I have done that before 100% there is a way of doing it on the programmer
    Norfolk
    3,000
    Only reporting what it said in the manufacturer instructions. You can find them on the www
    Apr 2012
    205
    Hi ultimategas
    Regman looks right as it says it in the installation instructions on the LHS of the sheet. Download them here.
    Oct 2013
    Hi did you find out how to reset the S17R?...having the same trouble as You would appreciate a heads up thanks Grant
    Norfolk
    3,000
    Refer to post 2, or down load the instruction manual.
    Sep 2013
    The instruction booklet does not contain the information required ,they do not included to stop the end user re-seting it them selfs
    Norfolk
    3,000
    www.horstmann.co.uk/downloads/.../Central.../S17-UserGuide.pdf‎Page 7 Resetting to default?
serviceplus s17r
serviceplus s17
serviceplus s21 engineer reset
service plus s17r call eng
Serviceplus s17 reset
