Plumbing & Plumbers Forum - Problem with dt20 programmer on worcester 30cdi system boiler
Discuss Problem with dt20 programmer on worcester 30cdi system boiler at UK Plumbers Forums; I have a problem with a newly installed system. On the display on the boiler the arrow which selects between 'off' 'timed' 'once' and 'on' for heating doesn't move it ...
    Apr 2013
    Default Problem with dt20 programmer on worcester 30cdi system boiler
    I have a problem with a newly installed system. On the display on the boiler the arrow which selects between 'off' 'timed' 'once' and 'on' for heating doesn't move it just stays on 'on'. Is this a problem with the programmer, the rf stat or a wiring problem. The hot water works fine.
    Oct 2009
    1,116
    Default Re: Problem with dt20 programmer on worcester 30cdi system boiler
    Are you trying to turn the programmer off for heating?
    Mar 2013
    76
    Iv only used these a few times, but each time iv installed one it hasn't worked out of the box, had to sync the programmer to the RF stat before it would behave - check the instructions and follow them and re-sync the connection and it should then let you turn on/off the heating
    SimonG's Avatar
    16,127
    If it's a new install get the installer back.
    R1CKY's Avatar
    Jul 2011
    Wales
    1,015
    The RF stat probably needs syncing with the programmer. There is a guide in the users handbook on how to do it.
    Apr 2013
    Quote Originally Posted by R1CKY View Post
    Have just spoken to Worcester, they say change the batteries in the rf programmer and re sync. Have been trying to sync but wasn't working, maybe because batteries were low. Will try on Monday. Thanks
    Apr 2013
    He works for me and he can't figure it out!
  1. Worcester 30cdi system pressure problem
    By alexlindley in forum Plumbing Forum
    Last Post: 27-04-2015, 06:48 PM
  2. Which tank for Worcester 30Cdi System Boiler?
    By fayraz in forum Gas Safe Register Forum - Public Forum
    Last Post: 23-08-2013, 11:05 PM
  3. Which tank for Worcester 30Cdi System Boiler?
    By fayraz in forum Plumbing Forum
    Last Post: 21-08-2013, 07:19 PM
  4. Power failure with Worcester 30CDi Boiler
    By Scott in forum Central Heating Forum
    Last Post: 11-10-2012, 08:53 PM
  5. Worcester Bosch 30CDi System Boiler with flue
    By Sowler in forum For Sale & Wanted
    Last Post: 28-03-2012, 10:37 AM
  6. Worcester Bosch 30CDi System Boiler
    Last Post: 28-03-2012, 09:08 AM
  7. worcester dt20 rf problem
    By dwb78 in forum Gas Safe Register Forum - Public Forum
    Last Post: 12-12-2011, 09:42 PM
  8. Worcester 30CDI pressure problem from yesterday, Help please....
    By yeha1 in forum Gas Safe Register Forum - Public Forum
    Last Post: 22-04-2010, 07:17 AM
  9. Replies: 6
  10. plumber to plumber advice
    By dan wood in forum New Member Introductions
    Last Post: 06-11-2007, 04:15 AM
how to connect dt20 to 30 cdi combi
dt20 programmer problems
Dt20 fine thread message
dt20 programmer battery replacement
