Results 1 to 15 of 15
Plumbing & Plumbers Forum - Im i mad
Im i mad
Discuss Im i mad in the Central Heating Forum at Plumbers Forums; Hi all first post hope your all friendly (no tin hat needed) Ok i am from the uk originaly but moved to Romania 3 years ago and live in a ...
    Sep 2009
    16
    Default Im i mad
    Hi all first post hope your all friendly (no tin hat needed) Ok i am from the uk originaly but moved to Romania 3 years ago and live in a lovely rural area but winters get so cold and with two small children we need heat.We have a vast amount of firewood for free (almost) Ok i installed an LPG combi boiler and used plastic 20mm pipes to run to the radiators and has run fine and kept the house warm for two years,ok so the problem simple realy it costs a fortune to run sooooooooooooooooooo at long last we get to my question.
    I want to install a wood burner with back boiler but still keep my LPG boiler also,so all you experts help me if you can,is it possible to connect the two together so i get the best of both worlds or am i totaly insane
    Any help advice taken on the chin like a man
    thanks in advance
    east london
    6,666
    Default Re: Im i mad
    some one else has just asked the same question run through the lists and find it theres a link to something call a neutraliser
    Feb 2009
    Liverpool
    1,972
    Try the Dunsley website, they've got some good stuff on there. you can also try Parkray, Rayburn. And even the Solid Fuel Association.
    When you get a clearer idea of what you want and if you need any more help come back on.
    Good Fortune
    Sep 2009
    16
    Quote Originally Posted by Bernie2 View Post
    Good Fortune
    Thanks for the replies thought i did explain
    Feb 2009
    Liverpool
    1,972
    What I meant was the sites mentioned would give you some ideas as to what is possible with your system.
    After you have got some ideas from them come back on if you like or need further help.
    Don't forget connecting a combi to what for all intents and purposes would probably be an open vent system is not something one does every day, they usually behave as two separate units.
    Also solid fuel fires are notorious for their control problems.
    But there is probably no reason why you could not do something.
    Its just that its probably better and safer for you to get the information from an actual manufacture whose literature you can refer too.
    Sep 2009
    16
    This might explain what i want to do as i said i have the LPG Combie installed
    Boiler stove central heating and hot water simple vented installation
    Anyone help
    SUPER MODERATOR
    REDSAW's Avatar
    Jan 2009
    sherrif county
    9,097
    does this help at ?.all.
    Attached Images Attached Images
    Sep 2009
    16
    Quote Originally Posted by REDSAW34 View Post
    No sorry that makes no sense to me
    Quote Originally Posted by expat View Post
    Anyone help
    This is a bit basic in info but its how i wanted to run it,but i would need to install another pump as the one running the gas boiler only runs when the LPG boiler is running ?
    And what i am thinking is when the wood burner is running at full pelt it will store any excess hot water in the tank ??
    Sep 2009
    16
    Here is update,
    all fitted and working very well,LPG boiler on timer to come on at 5'oclock in the morning to top up the central.
    Done safety test ie unpluging pump when fire was on no problems as fire took the excess heat away from internal boiler coil.
    Thanks for the guys on here (only a couple) who gave me good advice and to the ones who posted daft unhelpful stupid advice
    All fitted with 20mm plastic pipe no problem as i used brackets every 10 inches
    migoplumber's Avatar
    blackpool
    2,139
    all the above advice is good advice, you just have to understand it. as for clipping your pipes every 10 inches remember plastic expands 20 times more than copper, if it has nowhere to move to it will pop.
    Shaun, GS 233006, Engineer 2485197
    Sep 2009
    16
    Quote Originally Posted by migoplumber View Post
    Just read through it all and the stupid comments have gone
    ive cliped them so they dont go like spaggehtie
    Jan 2009
    130
    Expat can you be more specific on how you solved the problem of combeing two systems as i am looking at a wood burner linked to a combi boiler , cheers
  13. #13
    Sep 2009
    16
    Quote Originally Posted by billybongo View Post
    No problem ???? i have linked the boiler of the wood burner into the combi as if the wood burner was a radiator in easy to understand terms the pipe that would return (cold) goes into the bottom of the wood burner and the hot out of the top.I have also fitted a pump,two pressure relief valves and put a 30ltr expansion tank above the wood burner in the loft and last a pressure/temp gauge.
    How it works ????????
    Lets say we come home after being out all day we put on the combie set @ 25deg in the mean time light the wood burner,when the wood burner gets going the combie cuts out and when the wood burner dies down the combie cuts in.I have non stop heat now if i wish and i will recover the costs of the wood burner and plumbing parts after one winter.
    Most said it couldn't be done but i have and very very happy with the system.
    Forgot to say i made the serpent for the inside of the wood burner with 25m of 20mm steel pipe,good luck and stay warm
  14. #14
    Jan 2009
    130
    Sorry to be dim but is there anyway you could do a drawing of your setup as i cant quite picture it in my minds eye , cheers for any help .
  15. #15
    Sep 2009
    16
  1. Plumbing problem driving me mad!
    By Muushy in forum Plumbing Forum
    Last Post: 08-08-2009, 04:29 PM
  2. Water Meter Going Mad
    By wrecked_24_7 in forum Plumbing Forum
    Last Post: 16-03-2009, 10:36 AM
