Plumbing & Plumbers Forum - Myson Orion 40 B boiler
Discuss Myson Orion 40 B boiler in the Central Heating Forum at Plumbers Forums; Any body got any ideas?? no central heating or hot water. Electric to the mains and pilot lighting fine....-
10-09-2009 #1Phil79Guest
10-09-2009 #2Super Plumbing Forum Contributor
- Dec 2008
- 1,109
- Thanked 1 Time in 1 Post
Re: Myson Orion 40 B boiler
could be anything ..not enough info from you
10-09-2009 #3UK Plumbersforums Trusted Advisor.
- east london
- 6,666
- 9
10-09-2009 #4Phil79Guest
Room stat replaced about a month ago by another installer. A sparky has checked wired correctly and that power being recieved at the mains, which there is. Pilot lights fine but the burner will not ignite ?.
10-09-2009 #5Super Plumbing Forum Contributor
- Dec 2008
- 1,109
flue/gas valve 2 possibilities it needs an engineer as near impossible to diagnose on the web
Boiler 15mm gas supply pipes / which boiler
By Gixxerman in forum Central Heating ForumReplies: 27Last Post: 13-05-2011, 02:30 PM -
Advice on choosing a combi boiler please
By chubsy in forum Central Heating ForumReplies: 17Last Post: 21-02-2010, 02:25 PM -
Combi, system or regular boiler?
By reggieroo in forum Central Heating ForumReplies: 0Last Post: 30-08-2009, 01:56 PM -
Myson Apollo 40S boiler keeps shutting out!
By Kav69 in forum Central Heating ForumReplies: 4Last Post: 16-06-2009, 12:11 AM -
Separate pump in addition to the one included in the condensing boiler?
By hughs in forum Central Heating ForumReplies: 11Last Post: 10-02-2009, 06:28 PM
Kitchen unit backboards
