Plumbing & Plumbers Forum - Ferroli Optima 1001 - Hot Water.
Discuss Ferroli Optima 1001 - Hot Water. in the Central Heating Forum at Plumbers Forums; We have a Ferroli Optima 1001 and everything is working OK apart from the Hot water. Even at Minimum or Maximum on the 'Domestic Hot Water Thermostat Knob' the water ...
    GazSuttonUK
    Default Ferroli Optima 1001 - Hot Water.
    Even at Minimum or Maximum on the 'Domestic Hot Water Thermostat Knob' the water is scalding hot.
    Any ideas what this could be?
    Cheers.
    migoplumber's Avatar
    blackpool
    2,139
    Default Re: Ferroli Optima 1001 - Hot Water.
    the temperature sensor is broken, common fault. get it replaced by your local engineer
    shaun
    GazSuttonUK
    Thanks for your help.
    Much appreciated.
  1. Bungalow with requirement for instant hot water and more water pressure in bathrooms
    By David Salter in forum Bathrooms, Showers and Wetrooms
    Last Post: 06-10-2009, 11:56 PM
  2. Hwlo with wold water tank overflowing
    By philwilliams in forum Plumbing Forum
    Last Post: 13-04-2009, 08:57 PM
  3. Hot taps run cold - not the boiler, I reckon...
    By plumb-line in forum Plumbing Forum
    Last Post: 30-03-2009, 09:21 AM
  4. HELP - Ferroli Optima 601 - No Hot Water ?
    By bilabonic in forum Central Heating Forum
    Last Post: 05-01-2009, 06:36 PM
  5. Brown hot water
    By Leeky in forum Central Heating Forum
    Last Post: 14-12-2008, 02:50 PM
ferroli optima 1001 boiler
ferroli optima 1001
optima 1001 fault
ferroli optima 1001 boiler temperamental
ferroli optima 1001 hot water only when heating on
feroli optima 1001 year of manufactureferroli optima 1001 boiler not on-how to reset
