Results 1 to 8 of 8
Plumbing & Plumbers Forum - Central Heating Protector F1
Discuss Central Heating Protector F1 in the Central Heating Forum at Plumbers Forums; Hi all, I have a can of Fernox F1 to be applied to the system via a radiator - do you close both valves and then let some water out ...
    Plumbing Forum Contributor
    Oct 2008
    91
    Default Central Heating Protector F1
    Hi all,
    I have a can of Fernox F1 to be applied to the system via a radiator - do you close both valves and then let some water out thro the bleed valve - and then inject the contents of the can? How much water do I need to let out of radiator first?
    cheers,
    dave
    Aug 2009
    15
    Default Re: Central Heating Protector F1
    is the system sealed or open vented
    Oct 2008
    Scotland
    366
    yeh your right in closing both valves, then i would let enough water out by slight guess from the nut on rad to valve. little bowl a towel and shifter. then bleed via bleed screw or if sealed system, adjust pressure to 1 to 1 and half bar whilst bleeding rad.
    oh yeh open valves again!
    Oct 2008
    91
    Hi guys,
    It's a vented system - I presume by closing off both valves only a certain ( small ) amount of water will come out of the rad when I open the bleed screw
    Aug 2009
    15
    if you have the bottled stuff you can just pour it in the F and E tank
    Jun 2008
    123
    Quote Originally Posted by apcdave View Post
    Hi guys,
    If it's the F1 Express or the F1 Superconcentrate, then as you say, close off both rad valves (remembering to count how many turns you shut the locksheild by) and release the pressure in the rad via the bleed screw.
    Remove the bleed screw or cap from the rad and attach the can. empty the contents into the radiator. Be careful when removing the filling tube from the rad as the rad will now have some pressure in it.
    Re-fit the bleed screw, open up the rad valves (re-setting the locksheild to it's previous position) and bleed the radiator.
    Job done
    Mark
    Oct 2008
    91
    Thanks everybody - it worked a treat.
    cheers
    dave
    Jul 2009
    teesside
    101
    Smile Re: Central Heating Protector F1
    Quote Originally Posted by dmholt24 View Post
    no you can't !!! the missing bit is you must drain enough out the system for the chemical to enter system first! otherwise you will have a highly dosed header tank and nothing else!!
  1. central heating plan
    By jbolland in forum Central Heating Forum
    Last Post: 19-10-2011, 11:55 AM
  2. proposed central heating installation
    By jbolland in forum New Member Introductions
    Last Post: 20-07-2009, 07:33 PM
  3. Hot water is lukewarm but Central heating working OK.
    By fplumber in forum Plumbing Forum
    Last Post: 14-05-2009, 10:44 PM
how to add central heating protector
fernox f1 forum
fernox protector f1 superconcentrate
how much fernox f1 do i need
fernox f1 express central heating protector
how much central heating protector needed in system
how to add central heating protector to a vented system
